clutch problems
Old May 10, 2012 | 07:04 PM
jjansenrs's Avatar
jjansenrs is on a distinguished road
clutch problems
this is probably something simple to fix, but the clutch does not disengage fully. during my ride today, i noticed when i pulled the clutch in at stop lights it wanted to keep going, and after a while longer the shifts started to get hard. when i pulled into the garage and started it up again i put it in gear and it killed instantly. does it need to be bleed or what? also noticed after the ride the brake fluid was low so i filled that up and it still did the same thing. old fluid was a little dirty but very bad. it feels like there is no pressure when i pull it in until its really close to the grip.
Old May 10, 2012 | 07:10 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
Pull the slave cylinder and check for leaks if its not put it back and bleed it out...
First was the side stand down when you tried to put it in gear when you got home?
The fact that the fluid level went down can point to one of two (or maybe both) problems.
You might not have bled the system fully or you might have a leak in the slave cylinder.
I would start by pulling the slave cylinder off and disassembling it. While it is apart check for scoring in the bore and replace it if needed.
If it looks good clean it out real well and reinstall it.
Then bleed the system, making sure you get all the air out of the slave cylinder.
At that point you should be good to go
Guess I type to slow....
Old May 10, 2012 | 07:45 PM
Check for brake fluid leak around the MC by the lever too (you probably would have noticed this already if it were the problem). But just in case.
I had a leaky boot once and had to pump the lever a few times to get the clutch to work properly... that was a tricky ride home!
Old May 10, 2012 | 07:54 PM
jjansenrs's Avatar
haha, i did have the side stand down at first, whoops, now it will lurch forward and barely stay running, when i release the brake it drives about half the speed as it does with the clutch out with no gas. i'll try bleeding it and see if that helps.
Old May 10, 2012 | 09:44 PM
aja's Avatar
aja
How is your engine oil level?
Old May 10, 2012 | 11:37 PM
GTS's Avatar
GTS
Seasoned tech
Sometimes when the banjo bolt isn't horizonal and points up an air bubble can get trapped there. So once you bleed it at the bleeder on the slave cylinder bleed it at the upper banjo bolt as well to make sure you get all the air out.
Old May 11, 2012 | 04:47 AM
toeknee19's Avatar
toeknee19 is on a distinguished road
if the bike moves forward and you the the bike in gear with the clutch in, u need a new clutch basket. The teeth are worn on the basket.
Old May 11, 2012 | 04:59 AM
on a street bike, more so on a vtr, of the 99 possible things that could account for the clutch not disengaging, that would be item number 100
it's possible, but neither common or likely... now if this was a 1999 RM250 we were talking about..................
OP: on the vtr, clutch wonkyness almost always ends up being // air in the line // leaking line // seal in the master or slave cylinder..
the poster is correct in stating a severely notched clutch basket can cause issues with clutch disengagement, but it would take many miles to do so, and not come and go with length of ride.
rule out nothing till checked, but start with the other suggestions first.
Old May 11, 2012 | 05:37 AM
jjansenrs's Avatar
its only got 10 thousand miles on it. the clutch wouldn't go out that fast would it? we ride pretty easy on it too.
Old May 11, 2012 | 06:31 AM
NO, the clutch basket on the VTR1000F should not be worn to that point. It's not common, not normal.
Old May 11, 2012 | 07:15 AM
aja's Avatar
aja
The reason I ask about the oil level is that when I recently chancged mine, istarted it up and put it into gear almost immediately, the bike started to move forward for a second then stopped when I assume the oil was in full cycle.
Old May 11, 2012 | 09:03 AM
You should not be having a clutch problem. They are pretty tough on this bike. I have 90K miles on the stock clutch (I have replaced the springs but the clutch pack is still fine) and I do ride mine pretty hard.
Old May 12, 2012 | 05:30 AM
jjansenrs's Avatar
thanks guys just got to bleeding the clutch last night, that seemed to do the trick
wcavasos
Nov 28, 2008 07:20 PM
printdoctor
May 21, 2007 03:18 PM
Philipian Ricer
Sep 15, 2005 12:21 PM
mks8882
Jun 1, 2005 11:04 PM
Philipian Ricer
Feb 6, 2005 02:47 PM
