Clutch master cylinder assembly
Old Aug 5, 2014 | 03:23 PM
I wanna go FAST!'s Avatar
I wanna go FAST! is on a distinguished road
I got into a small accident and I broke off the clutch master cylinder assembly cup. I can just replace the cup right?
Here is a picture
I'm not too mechanical but to me this looks pretty simple. Also, if I can just replace the cup, is there anything I need to do to make sure the fluid is running to the clutch correctly? (I'm thinking like bleeding the brakes...)
Thanks for reading!
Old Aug 5, 2014 | 06:40 PM
rick's Avatar
rick is on a distinguished road
you are also missing the fitting that the hose from the reservoir connect to the master cylinder. might be cheaper to replace with a used master cylinder with the reservoir from ebay
after installation, you bleed the clutch like yo bleed the brakes to remove air from the the system.
Old Aug 5, 2014 | 07:02 PM
I'm going off of this diagram
1998 Honda VTR1000F A CLUTCH MASTER CYLINDER | Cheap Cycle Parts
I think I am missing parts: 6,8,5,22,4,14,30
Which hose are you talking about?
Old Aug 5, 2014 | 07:43 PM
rick's Avatar
I am sorry. You are right. no hose. You have the list correct.
I forgot superhawk had a much smaller cutch mc reservoir and it sits right on top of the MC. I was thinking about larger reservoir connected with hose, like on the front brake MC.
boxdogracing
May 23, 2010 06:43 PM
JayBird217
May 27, 2008 05:05 PM
Darrell400ex
Feb 17, 2008 06:42 PM
nineighthawk
Apr 26, 2007 10:04 PM
CNI Dawg
Mar 19, 2007 02:57 PM
