SuperHawk Forum
-   -   Chain & Sprockets suggestions? (https://www.superhawkforum.com/forums/technical-discussion-28/chain-sprockets-suggestions-19284/)
Pixtaker Jun 25, 2009 08:22 AM
OK, so I am the second least mechanically inclined person on earth. My momma always said, "If you want something done right hire good people to do it". Therefore, I'm a little out of my element here so I need some advice...
My chain has been making a little noise so I took it to the Honda dealer and they said the chain & sprockets need to be replaced. For a DID chain & JT sprockets installed they want $380.00. That sounds outrageous for a chain & sprockets but maybe I'm wrong.
Anyway, a friend says he can change them out no problem if I get the parts. Any suggestions of what, dollar for dollar, the best chain & sprockets out there are? It's still running the 530, although I'm not opposed to going with the 520 mod...just have never seen a reason to do it.
So what do you guys think?
cheapbastard Jun 25, 2009 08:33 AM
1 Attachment(s)
I just put a 530 DID gold chain and steel Drive System sprockets all for $182 from sprocketcenter.com
Attachment 29285
FL02SupaHawk996 Jun 25, 2009 08:34 AM
Pix, if the $380 includes changing the oil and rotating the tire then it's fair, otherwise run!
I'm running a 520 setup and love it! If you have a wrench willing to do the work, you can go to Flebay and find sets like this: http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
However, I like to touch and feel my new parts so I bought the chain & sprokets at a Cyclegear;) Just buy the strongest 520 o-ring chain you can buy and you'll be fine...
Good luck bro!
Erik S. Jun 25, 2009 08:36 AM
I paid $160 for my chain and sprockets. Sunstar sprockets and a DID X-ring chain. $380 is ridiculous, that's $220 in labor which is 3 hours or so, and that is a ridiculous time. Even without experience, you could change them yourself in an hour just reading the manual.
Find the sprockets you want, and the gearing you want, and buy your friend some beer.
Pixtaker Jun 25, 2009 10:10 AM
Thanks for the quick replies!
I'm doing a little reading on the chains but I'm still a little fuzzy on the sprockets and gearing. I spend most of my time cruising around town with the occasional highway trip up to Omaha (about 50 miles). I don't ride extremely fast I just like being in the wind.
Suggestions on how to gear it?
FL02SupaHawk996 Jun 25, 2009 10:13 AM
I've tried stock 16/41 and didn't like it cuz it was too long so I went to 15/43 which was too short causing buzzy vibs at hwy speeds, so went back to stock 16 in front with 43 out back and it's perfect for me...I commute 50 miles 1 way to work and at 80 mph it sits at 5K rpm in 6th gear...
FL02SupaHawk996 Jun 25, 2009 10:20 AM
+1, buy the beer 1st then everything else will fall into place;)
Circuit_Burner Jun 25, 2009 12:53 PM
http://i57.photobucket.com/albums/g2...6/DSC_0827.jpg
That chain looks too tight right there.
Way too tight.
Tight chains dont like you, and they try to do bad things to you and your bike.
nath981 Jun 26, 2009 04:01 AM
If you just like crusin around and really don't get with the program, the stock set-up is fine. I prefer the 520 conversion(-1,+2) for several reasons, mostly to do with reduced unsprung weight/spinning weight and quicker acceleration. Noticeable Improvement. i have Regina gold chain with Vortex sprockets, although Afam and supersprox are better according to Hawkrider. I have seen the afam and it looks better than the vortex in terms of build quality.
relative to doing the job yourself, get your buddy to help. You'll need a master link and mine was the rivet type and this requires a special tool to do properly. I bought a Motion Pro when I found out I needed to clamp the rivets, but others are less costly. This is not a job for someone with little or no skills, especially in terms of securing the rivet link properly, making sure the sprockets are installed securely and aligned/adjusted well. Once you've done it a time or two, it's no big deal, but you don't even want to think about that chain coming undone at any speed.:)
https://www.superhawkforum.com/forum...&pictureid=610
RuthlessButcher Jul 6, 2009 06:01 PM
If you add 2 teeth at the back do you have to add links to your chain?
nath981 Jul 6, 2009 07:57 PM
I would guess that you would, although if you dropped one tooth in the front at the same time, you might get away with it.
killer5280 Jul 6, 2009 08:18 PM
No. -1, +2, or any combination of these sprockets do not require lengthening the chain.
FL02SupaHawk996 Jul 7, 2009 04:56 AM
+1, You can use your current chain...no prob...
maverick Jul 7, 2009 05:37 AM
Hey pixtaker I only live about half an hour from you, and I would be more than happy to help with your chain or any other problem you're having on your bike so long as you buy the beer!
FL02SupaHawk996 Jul 7, 2009 05:40 AM
+1, Will Work For Beer:)
Circuit_Burner Jul 7, 2009 06:48 AM
Regina makes the best chains in the world.
opsmgr Jul 7, 2009 09:43 AM
Way too tight.
Nice spot. Twang ... I could play a tune on that :D
Paul
Otto Man Jul 7, 2009 10:25 AM
Also...make sure you RIVET the new chain, don't use a regular clip on master link!
Circuit_Burner Jul 7, 2009 12:01 PM
rivets suck compared to clip links, but Im not going to fight about this again , LOL!
Muhahaha
Hawkrider Jul 7, 2009 01:39 PM
With the right tool, rivets have the advantage. Problem is that tool is about $150. No thanks, even from the Master of One-Use Tools (me). I've been running a clip for about 10k miles and haven't had a problem. The last one kept popping off on me, but I didn't lose the side plate, so I lockwired it instead.
trinc Jul 7, 2009 01:55 PM
i bought my motion pro rivot kit on ebay for around $70 a 'few' years back.
best investment, tool wise, to date. i've loaned it out for 6x beer countless times...
tim
opsmgr Jul 7, 2009 01:56 PM
If you're very, very careful, you can peen the rivet over with a ball pein hammer. Not for me though, I'm too ham-fisted, so I bought the proper riveting tool.
It's easy on the storm/hawk though, as the chain doesn't need to go through the swing arm, so at a push you could do the riveting in a vise on the bench, rather than on your hands and knees ...
Cheers,
Paul.
alientestsubject May 25, 2010 09:23 AM
Sprocket Part Numbers?
Do most aftermarket sprockets have standard bolt patterns / spline patterns? im going to change over to 15/43. Could someone give me brands and part numbers? That would be the berries. thanks in advance.
BlackhawksFan May 25, 2010 11:10 AM
Not to jack the thread, but I am planning on the 520 conversion with the 15/43 swap. Been looking at different kits and found this one online: http://cgi.ebay.com/ebaymotors/HONDA...item563cb95f3c
Opinions? Or a place to get the kit for under $150?
mboe794 May 25, 2010 11:22 AM
That one sucks. Get this one. Much better chain. I currently have this same kit from sumofallparts on ebay.
Some people may not like that it comes with an aluminum rear sprocket. I plan finding out if there is really anything to worry about or not.
http://cgi.ebay.com/ebaymotors/HONDA...item563cb8f610
nath981 May 25, 2010 07:06 PM
I got the regina gold chain and the front steel sprocket and the rear alum vortex(which is the weak part of the kit). The rear vortex is soft and showed wear in a few thousand miles. i replaced it wiht an AFAM high tensil alum, so in my case it wasn't worth it. Also be prepared to but a tool to install the rivet link unless you buy a clip type chain link. Cost me a 100.00 for a motion pro tool. I would recommend getting a good rear sprocket in lieu of that vortex.
BlackhawksFan Jun 5, 2010 04:03 PM
Any opinions on this setup? Which chain setup would be the best. I don't mind paying extra for a better quality chain, but don't want to throw money away.
http://www.cyclesector.com/520_CHAIN...20kit-sale.htm
nath981 Jun 5, 2010 08:49 PM
You usually get what you pay for in terms of these items. I would go with the best you can afford, but be apprised that you will need a rivet tool to attach the chain, unless you choose to go with a clip-type master link.
Hawkrider Jun 5, 2010 10:32 PM
Driven sprockets are middle of the road. They will last if you take care of them....religiously. AFAM sprockets seem to be the best, or you can go with a Supersprox if you want something trick. The chain, it seems, you have a wide choice on. Most any name brand will do. We only make about 100hp.
super duper hawk Jun 6, 2010 12:07 AM
Why did'nt Honda use a Belt Drive?
