CCT question
I just picked up a 2001 and will be doing the CCT stopper mod. (Remove plunger head and fill the gap so it can't retract too far in the event of a spring failure.)
For those of you that have done this mod do you remember how long your spacer had to be? and what did you use for the spacer? I know every bike will be different and I will measure but I would like to make up a few different spacers of varying lengths before I start. I don't have a proper work area where the bike is stored. Having pre made spacers will save me time and driving. |
Why not go with manual ones right away ? You'll be in their anyway, and, will be much safer than spacers IMHO. :O)
Thought about manuals but, the PO replaced the auto CCT's not to long ago (as precaution), stopper mod is $0, and I don't have adjust them.
Don't remember ever having anyone have to adjust manual ones. Once they're in, you're pretty safe with adjustement.
I do get the 0$ point though. Anyway, if no one chimes in with the info, I believe I still have the OEM ones in a box at home. I can take a pic for you with measurements tonight. |
(Post 378818)
I do get the 0$ point though. Anyway, if no one chimes in with the info, I believe I still have the OEM ones in a box at home. I can take a pic for you with measurements tonight. ".........depending on your engine the stopper length is going to vary, I have seen them as small as 8mm long and as lond as 12, so dont think 1 size fits all. You have to measure each one and make the stopper to suit" |
Yes due to chain stretch. Whoever came up with the stopper had his thinking cap on
| All times are GMT -7. The time now is 03:45 AM. |
