Carbs spewing gas
Recently had a guy knock my hawk over with his truck now when I tried to start it and the carbs are spewing gas out of the hoses on the top where the air box sits. I drained the carbs and hit the float bowl with a screw driver to see if the float may have been stuck but when I tried to start it again it was leaking gas again. Any ideas?
Thanks VTRsurfer!
Sounds like you're going to have to pull the carbs apart and see what's up. Sounds like it must have jarred one of the floats to the point it's stuck. Good luck with it!
You could try tapping on the sides of the carb bolws to re-seat the float first... like with the butt end of a scredwriver or something.
Originally Posted by 7moore7
(Post 348945)
+1. Could be a bit of small debris from the bottom of the bowl got loose and lodged in the valve seat. I have seen this trick work for that problem. |
I tried bumping the carbs but no luck. Diving in Carb deep this weekend.
If the bike has been siting for a while, you may have varnish build up.
Gas will do that when it sits in carbs. A good cleaning of the internals is prescribed to get ride of it, and avoid future problems again with the same thing. If you are fortunate enough to live in a place where you may ride year round, well, this is not as common. However, if like some of us, you are plagued with old man winter, you need a fuel stabilizer in order to avoid this during those long winter months when the bike just sits. |
I live in VA and still ride pretty much all year around so the gas is usually never more than an week or two (at most) old.
ive had the same problem. my vtr sat for a few months. battery was almost dead and while i was trying to start it. wouldnt turn over or try to crank but it sounded like just fluid was moving. next thing i know ive got gas pooring on the flood. took off the tank and in my airbox was about 1/5 inch of gas.
any ideas. |
