Carb Sync Tool
Old Mar 15, 2010 | 01:15 PM
Erik S.'s Avatar
Carb Sync Tool
So, with the bike apart for the front end swap, I'm gonna do some of the important stuff before riding season.
I did a search of the web for Sync Tools.
Found this one:
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
Lots of pictures and good explanations of how they did it. Might try the 2 bottle method.
This might need to be moved and stickied for everyone's use??
Old Mar 15, 2010 | 01:20 PM
Syclone's Avatar
Boosted
I used the yardstick & tubes method, easy as pie.
FYI, several other similar threads - Carb Synch Tool Search
Old Mar 15, 2010 | 01:35 PM
NCDave's Avatar
yardstick method has worked well for me too.
Old Mar 15, 2010 | 05:51 PM
RWhisen's Avatar
Former Superchicken Owner
I bought one of these:
http://www.carbtune.com/
Old Mar 16, 2010 | 09:39 AM
mboe794's Avatar
I believe the yard stick is the way to go if your looking to do it cheaply. Worked well for me many times. But I recently invested in the Motion Pro sync tool, very similar to the carbtune posted above.
Old Mar 16, 2010 | 10:23 AM
YOUNGJESTER's Avatar
mad skill collector
YOUNGJESTER is on a distinguished road
So the next logical question is did you notice if the yardstick was inaccurate?
Old Mar 16, 2010 | 10:31 AM
Syclone's Avatar
Boosted
As long as you get all of your air bubbles out, it's just as accurate as anything else. You're not trying to measure specific vacuum readings, you're trying to see if the vacuum from the two carbs is the same. So, if the liquid in the tubes (I used red Caterpillar coolant) rises at the same rate on both sides of the tube, you're good.
Old Mar 16, 2010 | 10:36 AM
mad skill collector
I use the yardstick set up, I was just wondering why the purchase of the sync tool? Is there something he noticed? we missed?
Old Mar 16, 2010 | 10:41 AM
mad skill collector
I just took the time to read the bottle method and I will be making one of those next. thanks for the info.
Old Mar 16, 2010 | 12:00 PM
RWhisen's Avatar
Since I work on aircraft as a profession, I consider myself a tool-a-holic and am rather nit-picky about accuracy. That and it's cool to pull out of its little case to play with.....
I also use one of these tools to adjust the carbs with.
http://www.motorcyclecarbs.com/kl/catalog/2003/069.pdf
Old Mar 16, 2010 | 12:27 PM
Syclone's Avatar
Boosted
No, there's nothing that "we" missed, some people would rather buy a gauge set. It would come in handy for recording vacuum readings for future use, or for synching four carbs without having to do them two at a time.
Old Mar 16, 2010 | 01:55 PM
mboe794's Avatar
The yard stick and hose worked just fine. Mine only works on twins (although I have seen ones made for 4 cylinders) and isn't very professional looking. I have been between jobs for a while and have started to work on other peoples bikes, wheelers, sleds and such. That is why I spent the money on a proper tool. It has easily paid for itself.
Old Mar 18, 2010 | 05:35 PM
psyclown's Avatar
psyclown is on a distinguished road
Anyone ever use gas instead of oil or antifreeze for the yardstick method? It seems like it would be much easier to get rid of the bubbles.
Old Mar 18, 2010 | 05:54 PM
Syclone's Avatar
Boosted
I think gas would deteriorate the clear hose (and using black fuel line hose would defeat the purpose of the gauge) and would kinda stink. I used A/F because I had it on my shelf and it was red (easy to read).
Old Mar 18, 2010 | 06:46 PM
psyclown's Avatar
Ok, I thought the change would be easier to notice. If the oil is being sucked away from the carb you are adjusting, should you open the carb (throttle valve) up more or close it?
Old Mar 18, 2010 | 07:31 PM
Syclone's Avatar
Boosted
There's only one adjustment screw on the VTR carbs, so you want to adjust it whichever way levels out the fluid (with the ruler method anyway).
Old Mar 19, 2010 | 05:23 AM
psyclown's Avatar
I understand that but it is not as noticable I expected. If I know which way to adjust then I can be sure I'm am not adjusting the wrong way and further out of sync.
Old May 2, 2010 | 02:06 PM
alwayshonda's Avatar
alwayshonda is on a distinguished road
Rotating the screw clockwise will give the rear cylinder more vacuum, raising the fluid level for that cylinder.
Old May 2, 2010 | 06:02 PM
residentg's Avatar
TwinMax is pretty cool. Take a look:
http://www.rlmotorcycles.com/cgi-bin....72021&pid=582
JB
Old May 2, 2010 | 07:11 PM
nath981's Avatar
is the oil moving fast or slow? if it is moving fast, insert a baffle into both ends of the tubing(i used 1 inch pieces of WD-40 spray tube) and this will slow it down so you can adjust easily. You may have to turn the idling up a little to get it to idle once you hook the tubing up. If the oil starts to move up on one side, simply turn the screw the other direction a hair. Make sure you are holding the throttle spring forward so the presssure you put on it to turn the adjuster isn't giving you a false reading. Just try to get the oil to stabilize, i.e., not moving up or down, and you'll be good. The adjustment is minute.
Old May 2, 2010 | 07:25 PM
jay956's Avatar
i made the bottle setup. easy to use and no chance of anything getting sucked into the engine
nath981
Jul 16, 2018 02:20 PM
rearview
Sep 12, 2010 09:38 AM
mxer363
Aug 12, 2009 07:44 AM
reaper
Sep 22, 2007 10:15 AM
VTRFISH
Aug 16, 2005 10:57 AM
