Caliper Bolt Stripped
Old Feb 21, 2005 | 04:50 PM
vtr_rider's Avatar
vtr_rider
Need help.
I just had new BT-014s mounted. I'm guessing the guy at the shop when he re-installed my front calipers he used an air ratchet wrench or something and I've now managed to totally round out the lower caliper bolt in my attempts to get it off.
Please post suggestions as to how I might get the bolt free. It's a total write-off, so I'm thinking about using my dremel to cut a slot. Even if I do this, I'm gonna need some major muscle to get this sucker off.
Trying to avoid drilling it out and re-tapping...
Old Feb 24, 2005 | 10:04 AM
Texassuperhawk's Avatar
Texassuperhawk
Re: Caliper Bolt Stripped
Just a suggestion, I've used Torx bits to remove allen bolts when they get stripped. Just find one that is slightly bigger than the allen bolts hole and tap it in with a hammer, this will make it dig into the bolt in the areas that the allen wrench usually applies force. Then put your rachet on and give it a try. If it works then Yippe! if not move on to the easy outs.
Old Feb 24, 2005 | 11:34 AM
marmaladedad's Avatar
Hmm?
mystikkowboy - does that ruin the Torx bit?
Old Feb 24, 2005 | 07:11 PM
vtr_rider's Avatar
vtr_rider
Thanks for the replies. I haven't butchered this bolt any further...yet. I'm going to my buddy who is a mechanic and has access to easy outs and the rest. I've considered jamming a 9" allen into the bolt (1 size up) and trying. If that doesn't work I'll try a torx.
Does anybody know the details of this bolt? I've tried to order more but they are back ordered, coming from Japan. I'm thinking of going to the hardware store and haven't an example on hand. Thought I'd give the list a try.
Thanks again.
Old Feb 24, 2005 | 11:04 PM
Texassuperhawk
marmaladeboy----- I've never broken a torx doing this, but there's a first time for everything. You just gotta be careful to get it in there strait and not crooked or you'll definitely break something and it might be your fingers.
Old Feb 27, 2005 | 07:26 PM
vtr_rider's Avatar
vtr_rider
My mechanic buddie had it out in about 5 minutes, just hammered a ratchet allen in and gave it a good steady turn. I feel so much less of a man...
But I'm happy it's out. Thanks guys.
salmanilla2000
May 9, 2011 12:05 PM
salmanilla2000
Apr 27, 2011 10:41 AM
mikstr
Jun 9, 2010 04:39 AM
Reason
Sep 8, 2009 06:39 PM
Galaxieman
Aug 12, 2009 11:34 AM
