Bolt is stuck
Hey,
So my husband has a 98 superhawk and has been trying for over a month now to replace the rear tire. He can't get the bolt loose. He's not sure if its reverse threaded or not or if there's something he needs to do first. It is jacked up of course. He bought it used without a manual and the previous owner never had to change a tire on it. If I could get some advice on the best way to do this I would greatly appreciate it! |
Are saying that the Nut won't break loose or the axle is stuck? If it's the nut, use a longer breaker bar. If the axle is stuck, remove the nut, use something to protect the threaded end i.e.; block of wood, Etc. and strike it with a hammer while trying to rotate the axle from the sprocket end.
When reassembling it put a thin coat of lithium grease on the axle before reinserting it. This will prevent future difficulties. Re torque to 69 lbs ft. Enjoy |
I've wrestled with more than a few axles at the bike shop over the years. If it's just the nut, apply some heat (keyword some). Don't make it cherry red or anything. If it's the axle, have fun... A decent brass drift helps as does a friend. One twist and pull while one hammers and curses. When it's out, clean it up good on a wire wheel and coat with your choice of grease. I like white lithium for that.
They are on there pretty tight. Normal thread...I use an impact when necessary. Sounds like a good time to buy a Milwaukee cordless.
AV |
| All times are GMT -7. The time now is 03:52 AM. |
