Bogs out at 7k RPM
Old Dec 27, 2013 | 11:46 PM
Dean Byron's Avatar
Dean Byron is on a distinguished road
Question Bogs out at 7k RPM
Hi all.
I have an interesting err
I bought a VTR 1000 Firestorm 2000. Drove wel and throught the rev range but slow,but lazy not that big bang everybody was talking about. So i check the carbies and found 135 main jets. Got the right jets 185 and wow more power on low revs and pull away now without stalling. But bike bogs ot at 7k rpm.
So check timing. seems fine.
So i take of the top cover of air box and it goes through the revs and with some loads of power first time bike pics up in second.
What seems to be the problem. bike runs great, starts easy.
please advise?
Old Dec 28, 2013 | 01:11 AM
Wicky's Avatar
Check the timing isn't 180 degrees out. Easily done if PO has had a CCT failure and rebuilt top end and put it back together wrong as it will run but not past 7k very well.
Old Dec 28, 2013 | 07:02 AM
Dean Byron's Avatar
Hi there.
Thanks for reply
I have checked timing.
My way.
Turn crank up to " R T" then the cams shows on marks IR and ER outwards alighning with head top and cam lobes showing inwards up.
Turn Crank up to "F T" then the cams show on marks IF and EF ouwards alighning with head top and cam lobes showing outwards .
Does this sound right
Old Dec 28, 2013 | 09:03 AM
Wicky's Avatar
It can appear fine but it can be still 180 out.
www.vtr1000.org • View topic - Cam timing
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=28729
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=30309
Old Dec 28, 2013 | 10:35 AM
Dean Byron's Avatar
Ok
I did the timingf thing 180degree change on rear cams. Nou it really suck and stops at 5k rpm.
Should i change it back and do the front?
Old Dec 28, 2013 | 11:15 AM
Wicky's Avatar
Did you put the filter & airbox lid back on?
Old Dec 28, 2013 | 12:06 PM
Dean Byron's Avatar
yes did do. changed timing back now bike smooth again but stil bogs at 7k rpm. the previous ouk put in smaller jets that made the bike rev through but not so powerfull. with out airfilter bike runs great into red line!
Just dont understand. oem airfilter.
185 jets
air screws 2 turns out. standard needles
45 slow jets.
Old Dec 28, 2013 | 08:30 PM
KCCO's Avatar
Have you looked at hawks carb settings and change to match exactly? That could rule out a jetting issue. I'm not very experienced with a issue like this but that can't hurt.
Old Dec 29, 2013 | 01:31 AM
2wheelsagain's Avatar
From: Victoria, Australia (Bottom south east corner)
2wheelsagain is on a distinguished road
The rear carb has bigger jets than the the front. Whst fuel are you running? What plugs? What condition are they in?
Old Dec 29, 2013 | 11:17 AM
carmanbikeshonda's Avatar
carmanbikeshonda is on a distinguished road
Hi, I have heard this problem a few times, Check the fuel tap diaphragm for holes
Old Dec 30, 2013 | 03:18 AM
Dean Byron's Avatar
checked everything.
But if i remove the airbox cover leaving the filter in place then the bike goes like crazy to the red line.
what are the correct factory main jet size.
Old Dec 30, 2013 | 08:54 AM
CrankenFine's Avatar
Any chance of a partial obstruction in the snorkel?
People have reported insects and small critters' affinity for lodging in the airbox before.
Old Dec 31, 2013 | 08:36 AM
comedo's Avatar
Unless you're at higher altitudes, the stock main jets are 175 front, 178 rear.
Old Jan 2, 2014 | 03:32 AM
Dean Byron's Avatar
Thumbs up
Ok. They are 185 and 188. So i should bring them down everything else looks just fine.
Will try that first and let you know. Thanks
Old Jan 19, 2014 | 04:32 PM
cybercarl's Avatar
Could be a Factory pro jet kit installed.
</title> <meta name="Microsoft Border" content="none"> <style type="text/css"> .style1 { text-align: center; } .style2 { text-decoration: underline; color: #FF0000; } .style3 { color: #00FFFF; } </style> </head> <body text="#C0C0C0" bgcolor="#000000"
185 188 will be too large if your running a standard filter!!! Start with the plugs and air filter, then move onto jetting to suit. Don't forget to do a carb balance/sync after making any jet changes to the carbs.
hondahawk
Dec 10, 2014 01:27 PM
ChillyWaa
Nov 24, 2013 05:11 PM
Bradluck
Oct 13, 2011 02:50 PM
luv2insanity
Aug 31, 2008 08:05 AM
Ysabel
Aug 9, 2007 09:44 PM
