You should go find the guy that sold you that thing (that we tried to talk you out of buying in your other thread....) and see if he will give you (some or all of) your money back.
Originally Posted by Chrisguilday
(Post 354344)
I don't see a gasket for the that part of the pipe. #8 says rubber, but I don't see anything else.
The gaskets are number 6, and yes a leak free exhaust system is important if you want it to run right. |
Originally Posted by VtrInMtl
(Post 354352)
I don't mind buying a bike that's say $1600 and putting $1000 into it and also learn a bit about it, rather then buying a bike that's $2600 that needs nothing and never learning anything. |
(Post 354376)
Originally Posted by 7moore7
(Post 354377)
Great way of approaching it. Also, you'll take some hits from some of the people on here as you do, but it's a tough love kind of thing and a great way to lean; much better than to have everything sugar coated.
Also, I didn't buy this bike with the intention of it being in perfect, or even good condition cosmetically. I probably won't get my moneys worth if I were to put a bunch of money into it making it look new. I just wanted a bike that I could ride around and have fun / get to and from work. I paid $1600, and I think after a few hundred more, it will be more then good enough to ride. |
Best thing I did was buy a junker. But like you said, you won't get a financial return on investment, just a huge amount of knowledge. You can clicky on the picture in my signature to see my project if interested although some of the images got lost in it somehow??? I just realized this, haven't updated that one in awhile ;)
Wow! Just went through your whole build thread and I honestly haven't seen a bike I liked as much as yours in a long long time. Wish I had the money to do that with mine haha.
Maybe some day... |
The reality is that the one that "needs nothing" will need something in 2 minutes. So there is less disappointment this way.
"all bikes run on used parts" is a sign I saw at a junkyard once. Just be methodical, bikes dont give you alot of second chances if you install something wrong like a car. And forget about getting money back. Just move forward. |
Changing the oil / fluids and repairing the petcock as i type this! we will see what happens...
Good news! Runs great. Rode it about 20 miles today. It is definitely running rich. Previous owner had idle set to 2300 rpm... Put that at 1500 rpm but I think it needs to be at like 1200-1300. The bike makes popping noises on deceleration and some times makes a little backfire when I start it up.
Also, I hear a clacking / ticking noise. Is this normal? |
The popping: is the PAIR system still hooked up? Check on that. If its long gone, then yeah, its running rich.
Like you said, put the idle down to 1200rpm. They all click, if the tensioners are switched for manuals, just try and ignore the ticking. |
Originally Posted by matt365
(Post 354624)
Like you said, put the idle down to 1200rpm. They all click, if the tensioners are switched for manuals, just try and ignore the ticking. I don't think the pair system is removed. This thing in the picture below would be gone if it was right? http://i42.tinypic.com/ifweav.jpg |
Yes that would be gone. Also, a little cam chain (or whatever) tick is fine or expected cold. Does it make the same sound when warm? They usually dont.
(Post 354643)
Take a picture of the right side of your engine and post it please. Include both cylinders.
What's up with the gloves? Afraid to get your hands dirty? |
Originally Posted by RWhisen
(Post 354649)
