SuperHawk Forum
-   -   battery not charging (https://www.superhawkforum.com/forums/technical-discussion-28/battery-not-charging-28726/)
hardrider40 Jul 7, 2012 07:39 AM
my stator is reading 0 volts can my vr be the main cause of that or just a bad stator has anyone had to replace one before
GTS Jul 7, 2012 10:10 AM
How are you testing the stator? the regulator/rectifier is a pretty common problem with these things, especially if it's stock. So you might want to check that first.
