SuperHawk Forum
-   -   Anyone use Koso guages? Need help (https://www.superhawkforum.com/forums/technical-discussion-28/anyone-use-koso-guages-need-help-28284/)
smokinjoe73 May 15, 2012 10:04 AM
So I got what seems to be a koso guage (or a really close replica).
Do I need a diff fuel and temp sensor?
Also only registers to 4k rpm. How is yours hooked up?
Also cant find their phone # for help.
GTS May 15, 2012 11:00 AM
https://www.superhawkforum.com/forum...pgrades-27279/
Check out that link. He just used one and I think he said he had to geta different temp sensor and he used the later fuel level sensor.
Tach may have like a 2 or 4 stroke option that needs to be adjusted.
Here is their contact info. Contact
smokinjoe73 May 15, 2012 11:08 AM
Thanks GTS I did check out that thread. I ordered the newer fuel sender but gotta call koso about the temp sensor.
Still open to anyone who has first hand knowledge
GTS May 15, 2012 11:10 AM
Where did you get your gauges? Are they the same ones in the other thread? How much did you pay for them?
smokinjoe73 May 15, 2012 12:32 PM
2 Attachment(s)
I ebayed them, I am gonna post pics and results. So far looks like this. At the moment have seperate water temp, ambient temp and battery monitor.
Paid only $60 so am way ahead.
GTS May 15, 2012 01:45 PM
Nice, got a lot going on there. I was kind of thinking it'd be cool if the unit had outside ari temp built in rather than having to have a separate little gauge for it. Was thinking about going that route but even thinking just swapping out mine for the later model one, just need the connector to plug in the back though which I think is going to be the hard part to find.
smokinjoe73 May 15, 2012 01:52 PM
So gts, are you running a koso or just talking about adding ambient temp to stock?
GTS May 15, 2012 02:15 PM
No running stock now. Was looking at some of the other gauges being the ones I have are so hard to read at night. I'm sure that has a lot to do with the PO putting blue LED's in it in place of the green. But was thinking the other day it'd be nice to have an ambiant temp gague and I'd really like to have a clock.
smokinjoe73 May 15, 2012 07:36 PM
Someone in Hawkland has to be running kosos too.
8541Hawk May 15, 2012 07:51 PM
Where is Markus when you need him....lol
Have you tried sending him a PM with your questions?
Not that he has run one but when it comes to electrical stuff it's a good chance he might know something
RWhisen May 16, 2012 07:35 AM
He's hiding out since I asked him about the gear position indicator.
