Air screws do they have to be the same ?
Old May 20, 2010 | 12:20 PM
Jens_denmark's Avatar
Jens_denmark is on a distinguished road
the 2 air/fuel screws in the carbs, do they have to stand the same way or ?
I mean front cyl. 2 1/3 out
the rear cyl. 4 1/5 out
good or bad for the engine ?
Jens.
Old May 20, 2010 | 12:23 PM
Sounds like the rear pilot jet is clogged. The screws are normally a little different, with the rear being open maybe 1\8-1\4 of a turn more.
The fact that the rear is open so far ( around 3 turns out is as far as you should go before switching to a larger jet) and so different from the front points to a problem with the jet.
They can be cleaned but it is easier to spend the $5 and just get a new one.
Or replace them both while you are in there.
Old May 20, 2010 | 01:43 PM
Agreed... That different indicates that something is wrong... But it you set them right they will end up slightly different...
Old May 21, 2010 | 11:32 AM
Grasshopper's Avatar
Grasshopper is on a distinguished road
On the race SV with flat slides i'm running slightly different main jets because the rear cylinder seams to get more hot than the front. This is a fine tuning thing though that can only be done on a dyno and closely monitoring cylinder head temp and exhaust header temp.
Slightly differnent pilot / air screw adjustments is normal. What you are describing is way out of wack.
little squirt
Oct 4, 2009 01:38 PM
little squirt
Nov 15, 2008 02:23 AM
nfbzike
May 20, 2008 07:55 PM
BlackHawk996
Apr 28, 2008 02:58 PM
BlackHawk996
Apr 27, 2008 02:10 PM
