98' SH...won't start?
Old Jan 26, 2016 | 12:45 PM
118811's Avatar
118811 is on a distinguished road
Just picked this bike up about 2 months back.
Had to put a new fuel petcock diaphram on right away.
Just now went to start her up....cranks over but does'nt start.
Battery at static 12.76.
she ran fine yesterday.....so I feel compression is fine.
Spark?
Just trying to get an idea of possible issues.....before I tow her in to the shop.
Thanks!
Old Jan 26, 2016 | 02:12 PM
Been messing with the petcock?
Could it be PVLIR? The little vacuum line that attaches to the petcock should be on the rear nipple that points sideways, not the lower one that points down.
Old Jan 26, 2016 | 02:28 PM
ren's Avatar
ren
Starter relay? Mine gave out randomly, had something loose inside when I shook it compared to a new replacement
Old Jan 26, 2016 | 02:39 PM
118811's Avatar
I had a shop do the new petcock install
Haven't changed anything.
I'll have to look into the starter relay.
I bet it's the original!!
Thanks
Old Jan 26, 2016 | 04:28 PM
Cadbury64's Avatar
VTR virgin
We've all done it...is the kill switch on the right bar in the run position?
Are you saying the bike cranks over fine but won't fire?
Old Jan 26, 2016 | 04:37 PM
118811's Avatar
Yeah....I've done the kill switch on....on all my previous bikes!!
Yes, bike cranks over...sounds normal but won't fire up.
Lights etc all seem fine.
Could it still be main fuse, or starter relay?
Old Jan 26, 2016 | 08:15 PM
A shop did the petcock, returned it to you, it wont run?
Did you mention this little detail to the shop? Seems like they may have something to do with it.
Have you sprayed starting fluid into the air intake while trying to start it? That would be the first and easiest step.
Old Jan 26, 2016 | 08:41 PM
118811's Avatar
The petcock was done about 3 weeks ago & has been running fine....till today.
Yeah, I'll try the starter spray tomorrow.
Old Jan 27, 2016 | 02:25 AM
Wicky's Avatar
What have you done between it running and then not starting?
Old Jan 27, 2016 | 11:29 AM
118811's Avatar
Nothing.
Monday I rode the bike to the office,,,,came home and covered her up.
She sat out Tuesday, I played golf.
Yesterday I went out to start her......she cranks, but won't start.
After I finish my morning coffee, I am going to check main fuse.
Old Jan 27, 2016 | 12:36 PM
118811's Avatar
Ok....tried to start her up....cranking same as yesterday,
Took tail fairing off: checked battery connection, looked at rectifier (ok)
Starter relay looked fine...pulled the fuse out(good). Put it back together.
Then....she started right up!!!?
I hate intermittent issues.
Old Jan 27, 2016 | 02:10 PM
AndyMX47's Avatar
A couple other things that can prevent it from starting:
Kickstand switch
Clutch switch
Do make sure the petcock vacuum line is connected to the angled connection on the BACK of the petcock, not the vertical connection on the bottom of the petcock - even the shop (especially the shop?) could have fouled that up.
Old Jan 27, 2016 | 03:33 PM
118811's Avatar
Kickstand switch
Clutch switch
She ran fine to work (20 miles)
@ 60-70mph
Parked her shut her off....she started right back Up����
Thanks
Old Jan 27, 2016 | 06:15 PM
Cadbury64's Avatar
VTR virgin
I believe there are two types of RR, a shunt (old style) or MOSFET (new style). AFAIK the shunt types use a prefix SH... and the MOSFET use FH...
Old Jan 27, 2016 | 06:36 PM
118811's Avatar
I will look again when I'm under there.
All I remember as far labeling:
E-003 was printed on the up side.
It is definitely not stock or original.
It is only using one of the mounting holes.
Old Jan 28, 2016 | 03:05 AM
Wicky's Avatar
Sounds like this:
Zoe Zoe-MTU14-07-E003-07 Motorcycle Replacement Voltage Regulator Rectifier Assembly: Amazon.co.uk: Car & Motorbike Zoe Zoe-MTU14-07-E003-07 Motorcycle Replacement Voltage Regulator Rectifier Assembly: Amazon.co.uk: Car & Motorbike
Look at upgrading to a MOSFET > https://www.superhawkforum.com/forum...why-how-25117/
Old Jan 28, 2016 | 09:02 AM
118811's Avatar
Yep....that's the one that's on my bike.
neilb
Sep 10, 2007 04:49 PM
Tom Blum
Jul 13, 2007 05:46 PM
jivtrky
May 17, 2007 12:49 AM
Yardstick
Dec 25, 2006 08:18 PM
ivan.ventrella
Jun 16, 2006 11:36 AM
