Subframe brace
Old Nov 8, 2013 | 04:05 PM
Letsrideinsc's Avatar
Letsrideinsc
Subframe brace
I was searching the net today for a better handlebar, and when searching I found this guy: Image attached. I wonder if it stiffens the rear up, I wouldn't think so. I was thinking that it may function as the "dog ears" do on the Moriwaki frame, but I highly doubt that. After further searching for this part, I found nothing. Installs in front of the rear shock on the lower subframe mount.
Old Nov 8, 2013 | 04:10 PM
Stumpy's Avatar
Link to page plz need more info
Old Nov 8, 2013 | 04:29 PM
Letsrideinsc
Not that it's going to help: VTR1000F Spiegler Superbike Bar Conversion
Old Nov 8, 2013 | 04:34 PM
Wicky's Avatar
Pointless - as the ears / bracing on the VTR racing frames were done mistakenly. It was found the shock delivered to them was the problem. See post below from Roger.
Roger Ditchfield » Fri Jan 25, 2013 2:43 am
Hi Guys, In this thread there has been several references to the "ears" in the Spondon frame. This the story. The development of the VTR was originally given to Russell Savoury by Honda UK who employed the services of Mick Grant as a consultant. After more than a year the project had failed to achieve too much progress and while I was at the Suzuka 8 hour I was asked by HRC if I would be interested in taking over the project. I agree provided that Russel was happy to do that - which he was. When I took over and uplifted all the bikes and equipment from Harlow I had five modified frames. Enquiries revealed that Spondon were asked to do this by Mick to cure high speed straight line weaving. I then examined the dampers that had arrived only to find that they had been extended between 15mm and 25mm centre eye to centre eye longer than standard of 345mm! IMHO the "ears" were fitted in an attempt to cure a self inflicted problem. As already mentioned in previous posts no ST3 race bikes producing far more power than Russels best of 118bhp ever ran with this modification including mine. The standard frame was modified and I have done this modification on two customer bikes in the UK. I left the Spondon ears on my ST2 Production race bikes purely because they did no harm to the new Revolution suspension set up and the then ACU Minimum Race Weight Regulation for that class allowed then to stay there. If you have a VTR bike exceeding 135bhp I recommend the Standard frame modifications as used on all ST3s*
Roger Ditchfield
*Reinforced & braced areas on VTRs
Old Nov 8, 2013 | 04:41 PM
Stumpy's Avatar
Thanks That is what I was looking for
autoteach
Apr 22, 2007 12:54 PM
FullFlavorPike
Mar 6, 2007 04:03 PM
BMiller
Mar 4, 2007 03:16 PM
Radiaoktiv
Nov 20, 2006 10:25 AM
Radiaoktiv
Oct 18, 2006 11:27 AM
