Speedo healers?? high rpm's on highway.
Old Jun 11, 2008 | 10:14 AM
bob4pres's Avatar
bob4pres is on a distinguished road
i bought an 02 hawk this winter and the sprockets have been changed. it turns about 4500 rpm's on the highway at approx 70 -75 mph, and the nmileage is lousy (less than 25mpg) i dont know how many teeth on the spocket (haven't counted them up yet). i've read about speedo healers. are they hard to install? i'm also thinkin about changing to a less aggressive sprocket too. any thoughts on that? how many rpm's does a stock hawk turn on the highway at 70 mph? thanks, bob
Old Jun 11, 2008 | 10:20 AM
PUSHrod's Avatar
16t front, 41t rear. 4K rpm,@ 70 +/- in 6th. Check that your choke is completely disengaging after you start the bike when cold and have your carbs been balanced? The last mpg item is the tps, check that it's set to 4-6 ohms.
Gentle throttle control and a lubed chain got me as high as 44 mpg.
Old Jun 11, 2008 | 12:23 PM
FL02SupaHawk996's Avatar
Fastest Color
I'd guess it's setup with 15 tooth front and 43 tooth rear...take a GPS with you and compare that speed reading to your speedo. If there's a difference and you don't want to go to stock gearing 16/41 then you can get a speedo healer to fix it:
http://www.speedohealer.com/eng/order.htm
Good luck bro!
RC
Old Jun 20, 2008 | 05:53 AM
codfish124's Avatar
SuperCock roster
codfish124 is an unknown quantity at this point
just picked one up and verry EZ to install and theres a max speed recorder it a cool thing
Old Jun 20, 2008 | 05:56 AM
Fastest Color
hide the max speed button from the fuzz
Old Jul 11, 2008 | 05:31 PM
kshuck2's Avatar
BeautyHawk
kshuck2 is on a distinguished road
mine is doing worse, the PO put on a vortex setup, it runs about 5k rpm at 83mph(speedo reading) but the guys i ride with say we're doing 65mph... and my odometer is going crazy...
where did you get your speedo healer?
this is all i could find:
are there any cheaper?
Old Jul 11, 2008 | 07:39 PM
LineArrayNut's Avatar
I could ride in
that's actually a pretty good price
Old Jul 11, 2008 | 08:35 PM
RK1's Avatar
RK1
If it could pull it the VTR with stock sprockets would redline (9500 rpm) at 169 mph in sixth gear.
To find rpm at 70 mph? 9500/169 =56.21 (rpm per each mph) times 70 (mph) =3935 rpm@ 70 mph.
Here's the formula;
(rpm X #front sprocket teeth X tire circumference in millimeters) divided by;
(primary gear ratio X sixth gear ratio X #rear sprocket teeth X 26,817)
nominal tire circumference for 180/55/17 is 1975 mm
Also, gear ratios are on pg. 204 of the owner's manual. If you don't have one, primary ratio is 1.681 and sixth gear is 0.961
Plugging the sprockets you have into the formula will give you actual sixth gear road speed at given engine rpm.
Old Jul 12, 2008 | 11:43 AM
kshuck2's Avatar
BeautyHawk
Here's the formula;
helpful... but where do i mount a calculator on my bike?
Old Jul 12, 2008 | 10:48 PM
RK1's Avatar
RK1
Ha! Has to be a decent calculator also, not one of those 8 digit cheap ones.
I use the one on my computer to determine rpm at given 6th gear cruise speed, percentage error from stock etc.
Then I use the one mounted between my ears to keep track of how fast I'm actually going.
Old Jul 17, 2008 | 08:47 PM
reaper's Avatar
Instead of spending $110 for the speedohealer, you can order a $15 bike computer and get the same results, http://www.ldrider.ca/techpages/bicyclecomputer.htm
The only thing it does not have is a light to read the speed at night.
Old Jul 17, 2008 | 09:18 PM
handkaudio's Avatar
handkaudio is on a distinguished road
One of these came on my bike, and it has a little red light on it that kinda matches the gauges and I can see it at night great, I was thinking about selling it to get a speedo healer or fiberglassing a pos for my nav?
Old Jul 17, 2008 | 09:45 PM
Death Cattle's Avatar
thats not too far off from what rpm's its supposed to be at around 70mph. a little high though. i just installed a speedohealer today, and its so easy it will blow your mind. i got version 4, its extremely easy to install, the hardest part is find a place to put it (very easy aslo). its also ver easy to program with the online calculator. its an awesome device.
Old Jul 20, 2008 | 10:47 PM
kshuck2's Avatar
BeautyHawk
this would work, but im mostly worried about the odometer for every 50 miles i ride it adds another 5 that never happened, so since i bought the bike, theres 220 miles that never happened, chalked up on the odo. ...
on the upside, it makes it look like im getting 45 mpg with it... haha
Old Jul 25, 2008 | 09:08 PM
kshuck2's Avatar
BeautyHawk
got my speedo healer today... completely worth it. easy to install, and works great!
Old Jul 25, 2008 | 10:38 PM
a71goatboy's Avatar
OH CRAP!
a71goatboy is on a distinguished road
About the same RPM, but better MPG
I run about the same RPMs with a 15/43 gearing, but I'm pulling 35-40 MPG. Definitly sync the carbs, maybe a full tune is in order.
uchi
Sep 15, 2009 02:11 PM
luv2insanity
Aug 31, 2008 08:05 AM
jonlun
Jul 16, 2008 03:54 AM
DRIVEN2MADNESS
Jun 14, 2008 05:27 PM
wyldryce
May 16, 2007 07:59 PM
