speedo healer? Anyone using this product?
Old May 3, 2006 | 06:53 AM
supertwinSH's Avatar
supertwinSH is an unknown quantity at this point
Hello all,
I am new to this forum stuff. I just bought a 2003 Superhawk and did the gearing change (from 41 to 43 rear sprocket). Now the speedo is off 10mph from my GPS. Has anyone used the Speedohealer to cure the problem?
Old May 3, 2006 | 10:16 AM
superhawk22's Avatar
Welcome aboard. If you do a search you should be able to find some threads on this subject. I know a few people are using them while others are using bicycle speedos.
Old May 3, 2006 | 10:23 AM
Re: speedo healer? Anyone using this product?
Thanks for the info, I will try this search thing and see what I can find. I noticed your from Florida. I just moved from Jacksonville, FL to OKC,OK. Riding was better in Florida....Less wind!
Thanks again.
Old May 3, 2006 | 10:25 AM
Yeah, but you've got to have more corners! The only time I get my fix is going to the track in Jennings FL.
Old May 3, 2006 | 10:35 AM
Everything here is straight...very little corners around I miss my days back in San Diego where buddies and I got to carve much more!
Old May 3, 2006 | 10:39 AM
Go to the Ozarks, I hear there's some great roads up there.
Old May 3, 2006 | 10:43 AM
you said Ok not ARK. duh
Old May 3, 2006 | 12:02 PM
kai ju's Avatar
I have been using one for almost a year now and I'm very happy with it.
As I said in my original post it was a set it and forget it installation.
There has been only one problem which was water in the remote trigger that I have mounted on the bottom of the left handlebar switch.
The water temporarily killed the speedo but once it dried out it went back to normal.
Here is the link to my original thread that includes a pic as well as some other info.
https://www.superhawkforum.com/viewt...=asc&&start=30
Kai Ju
Old May 3, 2006 | 02:34 PM
Thanks for the info......My speedo healer should be here today..!!!! CAN'T WAIT!
Old May 4, 2006 | 05:49 AM
Speedo Healer is in and WOW! 80mph at 80 mph! And the little black button is the coolest! I am going to try to put some pics in to show & tell.
Old May 4, 2006 | 12:13 PM
pickle.of.doom's Avatar
pickle.of.doom
I have one ordered and on the way! Can't wait to get it, I have had some pass-bys with speed traps since I swapped sprockets last week, and all I can really do is hope and pray that my guess at speed is correct
macworld
Jun 20, 2010 09:38 PM
HRCVTR1000
Apr 16, 2009 04:44 PM
E.Marquez
Mar 9, 2009 12:43 PM
supertwinSH
Oct 22, 2007 08:53 AM
macworld
Jun 30, 2006 11:44 AM
