Question about 520 conv.
Old Jun 28, 2007 | 01:50 PM
bluethunder's Avatar
bluethunder is on a distinguished road
Question Question about 520 conv.
I just saw an ad for a 520 conversion to lower the final drive ratio from 2.56 to 2.87. Is this a worth while modification? I wouldn't mind a little more low end grunt as I'm not the type of rider who likes to drive all that fast. Only question is if you do this can you keep the front end down everytime you get on it? Or do you have to lay on the tank? Thanks
Old Jun 28, 2007 | 10:00 PM
trinity012's Avatar
Hi blue, this 520 set up especially w/15-43 alot of better pick up and k n filter, jet kit... but your spedo will not show the true speed any more about 7mls off.
Old Jun 28, 2007 | 10:09 PM
Speed_Demon's Avatar
I started by dropping a tooth in the front and it was a big improvement. I later went up two in the back. I like how the gears are spaced with 15/43 but 1st gear is a bit low. Great for wheelies though. Personally I'd stick with 530 because it lasts so much longer than 520. It does free up some rotating mass though.
Old Jun 29, 2007 | 05:19 AM
Thanks for the info, When you say a 530 set up last longer , do you mean as far as wearing out the sprockets sooner? Is a 530 set up stock?
Old Jun 29, 2007 | 05:21 AM
yep, 530 is stock
Old Jun 29, 2007 | 08:28 AM
XLSR-VTR1's Avatar
XLSR-VTR1 is on a distinguished road
I did the 520 switch, used the double gold chain and hardened alum rear sprocket....$200+ lasted a year! Stretched the chain, ate the sprocket... I bagged it and went back to a 530 and steel sprockets, rotating mass wasnt noticable 15k miles later, still like new.
I also bought a yellow box, its the speedo correction device from Australia. Works great and is fully adjustable to correct any gear changes you make.
Easy to install too.
Old Jun 29, 2007 | 08:44 AM
Thanks XLSR for the info. I did have some concerns with an aluminum rear sprocket. Hardened or not. So unless I can find this same system in a steel I guess I should bag it. If it last a year thats not to good. Are ther any good systems out there? I saw the other one on ebay. Thanks
Old Jun 29, 2007 | 08:46 AM
supertwinSH's Avatar
supertwinSH is an unknown quantity at this point
I just went with the JT 43 tooth reat sprocket (530/steel) and I love it....I also did the SpeedoHealer "speedo corrections" instead of the Yellowbox. It's geared down enough and still has range on the tank (100 to 120 miles per tank). And awesome wheelies!
At 5k I am doing 80 mph.
Old Jun 29, 2007 | 09:19 AM
killer5280's Avatar
You can find 520 sprockets in steel, which is the only way to go on a street bike in my opinion. I put my own system together from Bike Bandit with JT sprockets and an EK chain for about $110.
EK Sport Quadra 520SRX X-Ring Chain - 102 Links
$62.99 5258918
JT 15-Tooth Front Sprocket (Honda VTR 1000F Super Hawk 1998)
$19.17 5260871
JT 43-Tooth Rear Steel Sprocket (Honda VTR 1000F Super Hawk 1998)
$27.03 5265641
Old Jun 29, 2007 | 09:38 AM
XLSR-VTR1's Avatar
After the aluminum sprocket wore out I bought one of the stealth sprockets, alum carrier with the steel teeth ring, looked cool. I wasnt thrilled with it much either, it didnt last long and seemed to wear oddly. Then the chain stretched and the bike pulsated forward as the stretched part of the chain rotated.. Was just too funky so I went back to the stock setup and have been happy ever since. Sounds like others have had better luck, maybe it will work out for you.
Old Jun 29, 2007 | 01:53 PM
I've seen 530 setups last 30k+ miles if taken care of. I've seen 520 conversions get smoked in less than 4k. The chain stretches much faster and a stretched chain takes the sprockets with it. The only time I'd use 520's is for racing.
Old Jun 29, 2007 | 02:08 PM
Thanks K 5280, thats some good info.I will try to get the same package from Bike Bandit. Thats a nice price as the other company I called today was $210.00 for pretty much the same thing. Will also look into the speed correction unit
erno
Apr 21, 2012 07:28 PM
SnapAttack
Sep 12, 2007 07:11 PM
superdave
Jan 24, 2007 08:59 PM
EngineNoO9
Jan 23, 2007 09:21 PM
SillyHawk
Sep 20, 2006 07:34 AM
