pair removal plates
Old Apr 26, 2009 | 10:38 PM
superdutyd's Avatar
pair removal plates
After reading every post on this topic, I have a couple unanswered questions. If I use block off plates, I can just leave the reed valves in, without reversing them, as a gasket right? Also, if I remove the valve do I have to plug the fitting on the airbox?
Old Apr 27, 2009 | 12:19 AM
Yes, no need to do anything to the reed valve. Remove PAIR cap, replace with the block off plate.. your down. make sure you get the orientation of the block off plate correct... it only fits one way, any other way and it will not sit flat against the valve cover and have an exhaust leak.
Also reccomend ditching the OEM fasteners, using some socket head cap screws of a correct length, and a drop of med strength thread locker so they do not vibrate loose. Or drill um and safety wire them in place.
Old Apr 27, 2009 | 06:50 AM
chickenstrip's Avatar
chickenstrip
Best source for blockoff plates? I see 'em on Ebay for about $25.
Old Apr 27, 2009 | 07:30 AM
I think i paid a little less then that on ebay.. I got a set that was mis machined, seller checked his stock, found out I was correct and sent me a new set at no cost.
Old Apr 27, 2009 | 10:28 PM
superdutyd's Avatar
I made my own today at work. I will try them tommorow to see if they fit.
Old Apr 28, 2009 | 09:36 AM
dshakes's Avatar
dshakes is on a distinguished road
If those fit do you plan on producing some more? Would like to get em myself.
Old Apr 28, 2009 | 10:12 AM
chickenstrip
+1
Old Apr 28, 2009 | 12:46 PM
superdutyd's Avatar
I made 3 sets figuring I might start putting them on e-bay. I was going to list them for $20 a set. I figure for the forum guys $15.00 shipped (lower 48 states).
Old Apr 28, 2009 | 12:54 PM
budman's Avatar
budman is on a distinguished road
So where do we send our cash, I want the first set
Old Apr 28, 2009 | 01:21 PM
superdutyd's Avatar
I will see if they fit tonight, then I will make a post in the classified section.
Old Apr 28, 2009 | 09:18 PM
superdutyd's Avatar
I tried them tonight, and they fit perfectly. I planned on keeping the reed holder in for the gasket. In order to do this, the little reed screw would have to be removed since it sticks out, and of course the reed would come out. If you remove the whole reed assembly, none of this matters and it will work as is. I may take them back to work and machine clearance for the screw.
Old Apr 29, 2009 | 08:13 PM
superdutyd's Avatar
I machined a counterbore for reed screw clearance on the backside and now it fits perfectly with no mods to the the reed valve required.
Old Apr 29, 2009 | 08:25 PM
98blackhawk's Avatar
98blackhawk is on a distinguished road
i may be down for a set........
Old Apr 29, 2009 | 08:28 PM
dshakes's Avatar
Me too
Old May 5, 2009 | 10:45 AM
Viper6's Avatar
Viper6 is on a distinguished road
Me too
Me too. But what about block offs for all that plumbing to the cylinder heads and airbox I would want to dump as well... if you can pull a full kit including those I bet most would buy all that as well... McMasterCarr has all the stuff I'm sure, just wouldn't know which to use at this point...
just a thought
superdutyd
Dec 9, 2012 07:07 PM
CNI Dawg
Sep 13, 2006 07:37 PM
Texassuperhawk
Apr 10, 2006 11:29 PM
Texassuperhawk
Dec 26, 2005 11:15 PM
CNI Dawg
Nov 16, 2005 10:07 PM
