Oil Filter Heat Shield
4 Attachment(s)
After heat wrapping the front header immediately adjacent the water hose and deciding I did not want to wrap the entire header, it dawned on me the front header passed very close to the oil filter and something other than heat wrap could be done. Somewhat in a "can it be done easily and effectively" mode, I sketched a design from some quick measurements and made a paper pattern. I had some 22 gauge aluminum sheet stock, so I used the pattern to cut a blank which I then bent to fit. I also punched some cooling holes at the top of the shield and added a bit of hi-temp neoprene foam strips as vibration dampers.
The below pics show the heat shield installed without the chin cowl in place for clarity. The next post includes pics with the oil filter heat shield and chin cowl installed. You can also see the heat wrapped header which has not been painted with hi-temp yet (still drying) and I may safety wire the bottom wrap and ditch the hose clamp. |
Oil Filter heat Shield & Chin Cowl Installed Pics
4 Attachment(s)
I can scan & post the paper pattern if anyone wants it. Just let me know.
BTW, I cleaned up the chin cowl area for the "after" pics. |
Nice fabrication. In my ignorance, what is the benefit of heat shielding the oil filter? Thanks.
Why heat shielding?
Originally Posted by Josh
(Post 156314)
Whereas the real world effectiveness of these 2 mods may be marginal, they are quick and cheap to do and on a very hot day these mods could be the difference between continuing to fly low and trying to find shade and water on the side of the road or track with a boiled-over engine. |
looks good, nice work! Any heat reduction gained would be beneficial imho....
its easy if you have a 3D brain...
