SuperHawk Forum
-   -   newb carb setup (https://www.superhawkforum.com/forums/modifications-performance-29/newb-carb-setup-30016/)
Lamar5271 Mar 21, 2013 02:48 PM
newb carb setup
Hi guys. First post ever. 98 Hawk...So...I got my bike last fall and its my first do I was more concerned with riding than fixing. So I'm getting around to fixin it up. OK to the point. I've got my carbs off and here's the setup. 175/178 mains 50 primaries. Its got the needles with clips. Both are on second slot from top with one washer. D&D slip ons. Stock air filter. I've flipped the pair plates and still get a lot of popping while decelerating. Idle may be at 1000 or 2200 varies each time I stop. I found the rear choke broke st the carb also. Bike seems to run smooth thru the RPMs but idk. Anything I can do to this to make it run any better or idle smoother before it goes back together.
8541Hawk Mar 21, 2013 03:01 PM
Put #48 pilots in it.
Add a washer to the rear needle.
Modify the front slide per my set up thread.
Check the slides for extra lift holes and also for short slide springs. These indicate a DJ kit and you would have to use a different set up.
7moore7 Mar 21, 2013 03:02 PM
Christ that's the shortest version of your carb setup yet ;)
Lamar5271 Mar 21, 2013 04:46 PM
There's 2 holes in each slide. It also has long 12"? Springs. Could I just move the clip on the needle or I NEED a washer? Thanks for the help
8541Hawk Mar 21, 2013 07:22 PM
Well you don't NEED anything but I would plug one of the holes on the front slide (if you use the stock stacks) and get a #4 washer to add one shim to the rear needle.
Lamar5271 Apr 10, 2013 06:01 PM
I did exactly what u said. Pros...starts up a lot easier. Idles smoother. I can get the idle down to about 800 if I like. Maybe my imagination but I think it runs smoother in top rpms. Now the bad...from a stop I get no throttle sometimes. U really have to rev it and slip the clutch to even get moving. Only sometimes though. And my bike now has a bad flat spot at 3-3500 rpms. Tons of very loud popping on decel.pair system is gone and capped off. Even on the highway I have the play with the throttle cuz it kinda bogs down and has absolutely no throttle responce until u rev it up. Idk what to do.
8541Hawk Apr 10, 2013 07:39 PM
Raise the needles 1 clip ;)
Lamar5271 Apr 10, 2013 08:36 PM
Thanks. I'll let u know what happens.
cybercarl Apr 11, 2013 12:26 AM
Sounds to me like it's got a Factory Pro kit hence the 50 pilots and standard mains. There's one way to know for sure and that is to count the slots in the needles. DJ have 6 slots and FP have 5.
Lamar5271 Apr 17, 2013 11:32 AM
Ha. Front carb came right out off the engine. It wasn't even seated in the rubber. Back together runs great. I might raise my needles one clip to try to cure the popping on deceleration. Thanks hawk
cybercarl Apr 17, 2013 12:35 PM
Check you have no exhaust leaks first as this will cause popping on decel. https://www.superhawkforum.com/forum...ons/icon14.gif
Blackbetty Jun 26, 2013 02:07 AM
Picking up on posts about pilot jet size..
Just wanted to ask 8541Hawk and Cybercarl.. you mentioned #48 Pilots for this build. Im looking at a very similar build on my 05 storm with a FP 1.1Ti kit.
That kit come with #50 pilots.. Any reason why the #48's are better suited?
Also how does one go about buying them with the difference in the emulsion tubes?
For reference, set-up is:
05' Storm. TPS @ 490, PAIR Mod, Remus cans minus restrictors, Exhaust mod at 2-into-1 section (ground away the 'overlap' where it goes back into 2), OEM airfilter but blade removed on leading edge of filter element, Snorkel removed.
When I rebuild the card for the 1.1Ti I intend on removing the manifold restrictions that seem to be on both cylinders!? I only heard it being on one... guess mine is extra special.. either way it runs like a 650V2 currently :(. smooth but asthmatic at best.
Any advice greatly appreciated.
7moore7 Jun 26, 2013 05:19 AM
The emulsion tubes are separate parts, so they do not affect the purchase of the (main) jets. The pilot jets do not even interface with them so it wouldn't matter anyway.
I think that Mike suggested it because a high idle that creeps down to the set idle is an indication of running too rich at the bottom. Changing from 50's to 48 will help this. Adding a washer raises the needle very slightly which will give a little fuel back a little sooner. All you do is try to find a shop in your area or online that will sell you Kehnin Series 21 pilot jets size 48.
I'm barely familiar with a stock pipe setup. Running 2-into-1 I have no idea. Asthmatic seems like a good description of taking half the pipes off, though ;)
cybercarl Jun 26, 2013 08:56 AM
I believe that FP supply 50's to go with a full system ie. race header pipes as well as cans. But there are no set sizes as such and every bikes requirement will be slightly different. You may require one of three size pilot jets (45, 48, or 50) 48 being the more popular size. The size you use is dependent on what size mains and needle heights you have. The fuel mixture screws control mainly the amount of flow through the pilot jet but does taper off through the needles and mains too. When tuning CV carbs you should always ideally start at the top (mains) and work your way down.
CV Carb Tuning Procedures
Just by adding aftermarket race cans you will find that the standard mains do a pretty good job but the midrange and bottom end suffers slightly, hence the reason for shimming the needles and using a slightly bigger pilot jet.
Obviously with the FP kit there is no reason to shim the needles as they are adjustable. They also have a totally different needle profile to the standard needles so there maybe a requirement to up a size or two on the mains.
7moore7 Jun 26, 2013 09:39 AM
Unless you want to adjust halfway in between the needle clip "steps"
cybercarl Jun 26, 2013 09:57 AM
Indeed, good point, and that's getting right down to the nitty gritty fine tuning. Even with my FP kit, I still raise my rear needle the extra 10 though (standard shim) as in Hawks set up. https://www.superhawkforum.com/forum...ons/icon14.gif
Blackbetty Sep 6, 2013 07:07 PM
Awesome guys.. Cheers
Always good o get some further info on whats good in the dark art of carby tuning..
