New lightweight rotor
Old Apr 30, 2009 | 07:44 AM
Check it out boys, just purchased a seriously lightened rotor (about 3/4 of a pound lighter from what I can tell based on a quick Google search). Looks quite trick too!
http://home.cogeco.ca/~kmahli/RC/c2rotor2.jpg
http://home.cogeco.ca/~kmahli/RC/c2rotor1.jpg
Old Apr 30, 2009 | 08:25 AM
Erik S.'s Avatar
Ok, so they're trick looking and lighter. Where'd you get them?
Old Apr 30, 2009 | 08:30 AM
Bought it (it`s the rear unit) from a chap in Toronto, he got it machined by a place called C2 (?). He is also selling a "Swiss cheese" version (http://www.speedzilla.com/forums/hon...ar-rotors.html) While not an astronomical weight saving, it all adds up (along with AFAM 520 pitch aluminum rear sprocket and magnesium PVM rim). Reduced unsprung/rotating weight = improved suspension action, handling and acceleration. No downsides to that (other than the $$$$$)
Old Apr 30, 2009 | 08:53 AM
CentralCoaster's Avatar
1 lb saved at the tire is as good as saving 2 lbs of static weight.
The rotor though, being closer to the hub, is somewhere in between.
Old Apr 30, 2009 | 08:57 AM
The further from the axis of rotation the more effect it has (from an inertia standpoint). In terms of unsprung weight, it doesn't matter where it`s located. Either way, 3/4 of pouund is 3/4 of a pound am running a 180/55 BT-016 tire which is decently light too)
Old Apr 30, 2009 | 08:58 AM
Is there enough meat left to provide braking surface and to deal with the heat buildup?
Old Apr 30, 2009 | 09:02 AM
I hardly use the rear brake so I am not too concerned about it. If anything, it will make it easier to modulate.
Old Apr 30, 2009 | 09:50 AM
Truckinduc's Avatar
I did it to, but I went the free route and drilled my own.
I asked my waterjet guy. He sais he could cut rotors no problem. I may start a service where you send me your rotors, I have them cut, and I send them back.
Old Apr 30, 2009 | 05:35 PM
salmanilla2000's Avatar
SEXY!!!
Old Apr 30, 2009 | 06:13 PM
FL02SupaHawk996's Avatar
Fastest Color
nice Mikstr! But u wont neet that weight saving once you install those big slugs
RC
Old Apr 30, 2009 | 06:23 PM
arrrrrgh!!!! every little bit helps though, he he
Old May 4, 2009 | 07:18 AM
Bolted it up last night and went for a quick ride. Braking power is softer than before but I hardly use the rear brake anyhow (guess I'll never be a good cruiser rider then, lol). One the positive side, it means locking it up inadvertantly is almost impossible (a good thing, especially on wet pavement). Oh yes, and it looks wicked too
Old May 4, 2009 | 07:59 AM
nothing's Avatar
ride it out
does it look wicked? pics!
Old May 4, 2009 | 08:01 AM
Will post pics once all my mods are done (for this year, or ths part of the year, lol) I still need to get my shock reservoir installed. Then I'll be mounting a serious run at the VTR of the Month!!!!!! he he
Old May 4, 2009 | 09:02 AM
Stevebis1's Avatar
What about warping and possible cracking? It looks like A LOT of area has been removed.
What happens if this fails in traffic? If someone goes down and is injured or worse because of a broken rotor I can just imagine the law suit...
Old May 4, 2009 | 09:05 AM
yruyur's Avatar
I think ones that are cut like saw teeth would be pretty cool
Old May 4, 2009 | 10:31 AM
I live in Canada, we are not quite lawsuit central yet (with all due respect to my American friends). Besides, as I mentioned earlier, I hardly use the rear brake at all (its only use is to stabilize the bike in some circumstances, hardly taxing enough to cause it to fail). Catastrophic failure of the rear rotor is very far from top of my list of worries....
Old May 5, 2009 | 02:31 AM
shayne's Avatar
Something like these?
Old May 5, 2009 | 06:07 AM
chickenstrip's Avatar
chickenstrip
Man, you've got some serious work into that bike. Looks like the whole motor has be crinkle coated (not to mention other bits here and there) - true? Difficult to keep clean? Are those mirrors effective? About the same as stock? (Ooops! Thread hijacking - my bad.)
Old May 5, 2009 | 08:37 AM
Stevebis1's Avatar
+1 And I also want to know about those mirrors
Old May 5, 2009 | 12:02 PM
Malice's Avatar
Hey mik,
How much weight did you save with the magnesium rims?
________
Couples Webcam
Old May 5, 2009 | 12:09 PM
Not sure as I didn't weigh them , or the stock ones for that matter. I can tell you that the PVMs are MUCH lighter (the front, in particular, is ridiculously so). Just have to steer clear of potholes, an on-going job here in Quebec....
Old May 5, 2009 | 12:11 PM
yruyur's Avatar
that's pretty close to what I was thinking, I was thinking a little sharper edges
Old May 5, 2009 | 12:15 PM
I have seen shops adverstise on eBay that offer this service and create some really nice rear rotors (albeit they look a bit heavier than my new one, he he) Do a quick search and you'll surely find one
Old May 6, 2009 | 02:13 AM
shayne's Avatar
Yeah, I have used wrinkle finish paint on the engine. I think it is a good finish and easy enough to keep clean using something like what we call truckwash in Australia. It is a detergent you mix up, spray on, and hose off after a while. I think if you were to wash it by hand you could only use a sponge so as to not mark the finish.
The mirrors are a custom job I did myself, using a combination of the Honda mounts and an aftermarket mirror. Bastard of a job that took ages, but worked out in the end. Visibility is a bit better than the Honda mirror as they are a bit longer.
Sorry for the thread hijack!
Old May 6, 2009 | 05:51 AM
No problem Commonwealth brother, lol
Babelfish
Feb 5, 2016 10:51 AM
Rollin20z
Dec 9, 2011 04:12 PM
flyinbrian24
Apr 29, 2011 09:57 AM
mikstr
Jan 10, 2010 06:10 AM
