need help
Old May 11, 2005 | 03:28 AM
BooYeah's Avatar
BooYeah
need help
I know cars but not bikes
I know brakes but not lines.
I want to put on a set of goodrige lines, but i don't know which side the longer one goes on i am guessing left?? Do you put both of them connected to the resivour just side by side? a photo would be great.
Old May 12, 2005 | 04:57 AM
VTRDarren's Avatar
VTRDarren
Trust your instincts... longer one goes to the left side. And yes, they both get attached to the master cylinder, and the kit should have come with a longer bolt to accommodate the side-by-side mounting of the lines up top.
It really is as simple as it looks...don't let your brain get in the way ;-) Dive in man, dive in!!
Old May 12, 2005 | 12:27 PM
BooYeah's Avatar
BooYeah
Re: need help
I found a webpage that detailed it and put my mind to rest, got them done and going to ride in a little while, we will see what we think, no we won't, yes we will, shutup, no you shutup, i know you are but what am i
Old May 12, 2005 | 12:58 PM
marmaladedad's Avatar
Hmm?
Re: need help
You DO know you're not supposed to taste-test the brake fluid, right??
Old May 12, 2005 | 06:14 PM
cdyer77's Avatar
cdyer77
DO NOT PUT THE LINES SIDE BY SIDE!!!!! There should be a washer that mounts between the lines.
The kit should have come with 3 washers, 1 against the end where the banjo bolt threads in, 1 for between the two brake lines and a third for the outer line against the head of the banjo bolt.
Without all three of these, brake fluid will seep out and your brakes wont work.
Old May 13, 2005 | 01:29 PM
NOrrTH's Avatar
Re: need help
Post that web page please. My Goodridge lines just came in today. I wanna get it done this weekend.
Thanks
Old May 13, 2005 | 09:59 PM
BooYeah's Avatar
BooYeah
Re: need help
http://www.kamware.com/vtr1000f/bl1.htm
only cause i love you north
you owe me one 8)
newleader
Jun 18, 2010 09:07 AM
mattvdsande
Mar 16, 2009 11:12 AM
cagedruss
Jun 20, 2008 06:19 PM
Scumbag
Dec 11, 2007 09:08 AM
redman
Aug 25, 2007 09:09 AM
