SuperHawk Forum
-   -   Installing superbike steer (https://www.superhawkforum.com/forums/modifications-performance-29/installing-superbike-steer-15730/)
TommieVtwin Aug 7, 2008 02:45 PM
Hi there,
I'm thinking about installing a superbike steer on my VTR Superhawk, but I do not want to adjust the fairing panels. There are kits out there but they require you to do exactly that. I don't care about having to modify the brakelines and such.
Is there a way to do it without having to touch the fairing panels and if so, where and what to buy?
filter69 Aug 7, 2008 02:52 PM
Originally Posted by TommieVtwin (Post 175454)
Hi there,
??? ..... Ummm Ahh What ?
Are you saying you would like to install a Steering Damper on your VTR1000F and would like to avoid cutting into the farings or just dont wanna take them off.?
I would think scotts makes one that mounts right on top of the triple not sure what model it is thou.]
Here found one .... http://www.kneedraggers.com/details/...0--606253.html
But if you think you need one then there is something wrong with your bike or the susp. setup to be quite honest. this bike handles great and all the damper is gonna do is slow down the bikes reaction. but YMMV..
TommieVtwin Aug 7, 2008 03:19 PM
Not a steering damper but replacing the steering handles with a superbike bar. That offers a more comfortable riding position and better control over the bike.
English is not my mother tongue so I do appologise for any confusion...
filter69 Aug 7, 2008 03:38 PM
My bad And welcome to the forums heres a link some what concering superbike bars and
the vtr
https://www.superhawkforum.com/forum...superbike+bars
filter69 Aug 7, 2008 03:41 PM
Here's a site you can make some bars that will work for the vtr like these angled risers.
http://www.mandp.co.uk/productInfo.aspx?catRef=557428
the vtr
and this one from Soopa Bling
superbling Aug 7, 2008 05:32 PM
Honda VFR clip ons from 1990-2001 are 41mm and are about as high was you can go without trimming fairings.
If you want to use superbike bars for great leverage (easier turning) and NOT trim fairings, I'd suggest finding the lowest (shortest) riser and a flat bar also called a drag bar.
Remember, the risers will need to be high enough to allow the handlebar to clear the tops of the fork tubes. Measure that distance and that will give you a good idea of what to look for and if this will even work without trimming plastic.
