Injection manifold for turbo
Long winter is coming and I have to keep myself busy so I decided to loose the stone age carbs on my SH, what those honda engineers were thinking....
So first step in fuel injection, it doesn't sound easy and in fact it's not, I have made an attempt to make a manifold with aluminium tubing and it failed since I don't have the right welding equipment and aluminuim is not stretchable to make some nice velocity stacks. Then I went to get stainless tubing...Too goddamn expensive and hell hard to work with. So I got back home and thinking and I had an idea. I have seen that old ABS potato cannon I made years ago, it was strong enough to launch potatoes in outer space it should hold a small 10 or 15 psi, it's light, gas resistant, insulate from engine heat, and resist to temps up to 230 deg F and anyone with a stove and half a brain can make something out of this stuff. So just started this week. It turned out to be very pleasant, easy and cheap to work with this material and the contact cement is really strong.
It's not in it's final stage yet but it goes well.
inderocker
Oct 17, 2016 11:01 PM
iamanonymous
Mar 1, 2007 04:58 PM
Rufion
Jan 14, 2006 10:26 PM
