FUEL TANK
Old Jul 27, 2013 | 01:03 PM
SPEED DEMON1322's Avatar
SPEED DEMON1322 is on a distinguished road
FUEL TANK
do the later year super hawks have a bigger gas tank on them? i have been told they do and was wondering if so, would they fit my 99 hawk?
Old Jul 27, 2013 | 01:06 PM
Not in the U.S., only abroad. They are nearly unobtanium. You'd have better luck a VFR tank swap.
But yes, they fit to answer your last question.
Old Jul 27, 2013 | 04:19 PM
davidka's Avatar
I believe I read that the larger Euro issue tank also requires a matching (smaller) air box.
Old Jul 27, 2013 | 04:49 PM
I think airbox is the exact same. The petcock has to be re-located to the frame rather than under the tank though... that may be what you're thinking. But I think it's a fairly easy conversion...
Old Jul 27, 2013 | 06:48 PM
jerryh's Avatar
I wouldnt mind an old school petcock with reserve.
Old Jul 27, 2013 | 11:52 PM
GTS's Avatar
GTS
Seasoned tech
Yeah just make sure to have your 8mm socket and ratchet so you can lift the tank and get to the petcock to put it on reserve. But you do have a reserve as I the light goes on when you get to the reserve portion of the tank. At least on the earlier models.
Old Jul 28, 2013 | 12:22 AM
jerryh's Avatar
Be sweet to mount one on the left, maybe near the choke
Old Jul 28, 2013 | 12:53 AM
Why? Your bike already turns the gas on and off for you and like stated above, has a reserve.
Old Jul 28, 2013 | 04:24 AM
cybercarl's Avatar
Airbox is the same and yes the diaphram/petcock is mounted separately with a single hose that runs to an elbow mounted on the tank.
If you want a petcock with a tap so you don't have to use an 8mm spanner then the Varadero ones fit. But you need to have the separate diaphragm. Handy with the 19L tank instead of the elbow, otherwise just remove the petcock/diaphragm along with the tank and there is no fuel leakage.
Old Jul 28, 2013 | 04:29 AM
jerryh's Avatar
These bikes dont have a reserve. I dont like diaphrams on petcocks. They can leak and or leave you stranded. I have swapped out petcocks on other bikes to get rid of them. Not as easy with the location on these bikes. With a manual petcock with reserve, meaning two different heights inlets, you know 100% when you have a gallon left. If I could figure out how to do it on this bike I would
Old Jul 28, 2013 | 04:30 AM
jerryh's Avatar
I'll look into that, Thanks!!
Old Jul 28, 2013 | 05:06 AM
supertim996's Avatar
supertim996 is on a distinguished road
Bigger tank
I've been reading about the bigger tank, it's 5 gal vs. 4.2 gal on the U.S. fuel tanks starting in 2002 I believe. I'd love to have that little extra fuel myself.
Old Jul 28, 2013 | 05:19 AM
Wicky's Avatar
25L / 5.5 gallon tank fitted to VTR
www.vtr1000.org • View topic - Me petrol Tanker pics!
Old Jul 28, 2013 | 06:32 AM
Sounds like you've experienced this first hand?
Old Jul 28, 2013 | 04:44 PM
jerryh's Avatar
Yes and set in my ways. I can remember to shut off the petcock when I'm done for the day and I like the promise of a gallon at the end of a tank.
Bugged me on the blackbird too
Old Jul 28, 2013 | 10:45 PM
msethhunter's Avatar
Originally Posted by Wicky
Please don't take offense to this, but that looks like hell.
Old Jul 29, 2013 | 01:18 AM
Wicky's Avatar
None taken as its not my bike
However it is a pragmatic solution to adding extra fuel capacity it does the job.
Old Jul 29, 2013 | 10:56 PM
GTS's Avatar
GTS
Seasoned tech
Does the light turning on not give you the same thing as a reserve? Just it doesn't shut the bike off so when you're leaned over in a corner and the bike falls flat on it's face causing you to have to take evasive action to keep from crashing and making you have to reach down and turn the valve. Instead it just comes on and says "hey! you're now on reserve!" I get the not liking vacuum actuated petcocks but you DO have a reserve. I guess you could just take the spring out of the vacuum actuator and maybe even install it on the other side of the diaphragm so that it's always on. Then you'd have both reserve and a non-vacuum actuated petcock.
Old Jul 29, 2013 | 10:57 PM
GTS's Avatar
GTS
Seasoned tech
I agree that tank is kind of ugly but it looks like they did a decent job at it. I would soooo love to get my hands an a euro tank!
kostritzer
Jun 13, 2012 10:34 AM
Fox
Dec 14, 2010 11:46 AM
seb421
Feb 4, 2009 05:49 AM
RedHotFireStorm
Dec 11, 2006 05:44 PM
Ogre8472
Oct 11, 2006 09:24 AM
