130 hp what does it take
Old Sep 14, 2009 | 06:30 PM
skindonor69's Avatar
skindonor69 is on a distinguished road
what does it taketo get 130hp out of a hawk.I have stage 1 jet kit,k&n filter,and yoshi pipes.what else do I need to get 130hp out of it?
Old Sep 14, 2009 | 06:35 PM
joshuatest's Avatar
OUCH... MY A$$ HURTS!!!
see my sig line?
Old Sep 14, 2009 | 06:36 PM
joshuatest's Avatar
just kidding....
I don't know that I would wanna push the HP to far, probably like building a drag car... longevity might not be as long
Old Sep 14, 2009 | 07:07 PM
LineArrayNut's Avatar
I could ride in
https://www.superhawkforum.com/forum...wet#post194877
Old Sep 14, 2009 | 07:40 PM
An RC51
Old Sep 14, 2009 | 08:10 PM
bring your cheque book, or gold card...
Old Sep 14, 2009 | 09:35 PM
lynchie's Avatar
AZ RIDER
bigger mice
Old Sep 14, 2009 | 09:57 PM
jbaxx's Avatar
Honducati
An RC51
Haha, beat me to it cap!
Old Sep 14, 2009 | 10:27 PM
Just_Nick's Avatar
Who are you?
A different bike. You can push 130hp, but it's probably going to be like riding a time bomb. You're better off going for lower numbers or with a different bike.
Old Sep 15, 2009 | 05:25 AM
it all depends on whether you mean at the crank or rear wheel. 130 hp at the rear wheel would likely result in an engine whose long-term reliability is patchy at best. On the other hand, 130 crank hp would land you @ 115 hp at the rear wheel. I am in that general area, have a look at my signature for details.
Old Sep 15, 2009 | 06:41 AM
Jim TT's Avatar
Jim TT
· Higher lift longer duration cams degreed using dial gauge and degree wheel to get lobe centers around 104
· Oversized intake valves
· High compression JE pistons with valve pockets milled to proper clearance (assemble and test with clay).
· Milled cylinder head
· Five angle CNC valve job (fast by Gast does this - http://www.fastbygast.com/ )
· I would consider Falicon crank and rod treatment
· High output coils
· I would undercut the transmission gears
· Re-jet all three main card circuits.
Old Sep 15, 2009 | 07:35 AM
I could ride in
OK Guys. I thought that Italian fellow had the highest normally aspirated dyno verified rear wheel run at 120? The rumi race bike was higher but had no low end AT ALL. To get to 130 RWHP will take more than most are willing to massage the motor. I'm w/ some, buy an I-4 liter bike if you want that sort of thing, but that wasn't the OP's question. I can't use what I've got already Most of the time, and when I want More I'm already well into the illegal range and this bike gives me more smiles per mile than anything I've ridden...
Old Sep 15, 2009 | 08:37 AM
Moto Man's Avatar
Duc Hawk
nitromethane?
Old Sep 15, 2009 | 09:16 AM
I could ride in
I ran it my ZX-7 along with isooctane and MTBE to a max of 10%. It was good for a couple 10ths and 7 or 8 mph in the quarter. But I got all those adjuncts for free...
Old Sep 15, 2009 | 10:58 AM
I beleive Roger Ditchfield (Revolution Racing in the UK, he did a lot of work for Moriwaki/HRC on te bike) got mid-150s hp out of his racing VTRs, but those were EXTENSIVELY re-worked.
Old Sep 15, 2009 | 10:59 AM
I could ride in
rear wheel dynoed?
Old Sep 15, 2009 | 11:16 AM
FL02SupaHawk996's Avatar
Fastest Color
An RC51
+1, this is probably the quickest and cheapest way yo get there cuz these day's you can pickup a nice RC for $5K, while reworking the SH motor will cost quite a bit unless you have access to a second motor cheap and do all the work yourself like; flowed heads, HC pistons, OS bored cylinders, OS valves, full exhaust system, lightened flywheel, light weight rods, stronger & lighter crank, velocity stacks, etc...
Old Sep 15, 2009 | 12:05 PM
killer5280's Avatar
Much cheaper and easier to just get another bike.
Old Sep 15, 2009 | 02:47 PM
JamieDaugherty's Avatar
Where is the fun in that? Honestly, anyone with a checking account can buy a fast bike, but it takes talent and hard work to build one yourself. My 1098 has 170 rear wheel hp but if I built my VTR up to have 130 I think I would enjoy it more. At least there would be a greater sense of satisfaction about the whole thing.
Old Sep 15, 2009 | 03:17 PM
RCVTR's Avatar
Bob Hayashida got 130-135 RWHP reliably, using a massaged stock crank with stage 2 cams, Carillo rods, JE pistons, HRC ECU with no rev limiter and lots of attention to detail. He broke two cranks trying for more, but could run all season at that level.
Except for the brittle wrist pin that broke and caused the connecting rod to saw the case in half...
Anybody who got more out of a VTR engine used a forge crank. They only made 18 or so of them and they were outrageously expensive.
The ECUs are almost impossible to find, so getting the RPM you need for 130 HP is not going to be easy.
Old Sep 15, 2009 | 03:26 PM
killer5280's Avatar
Yeah, I know. Believe me, I know.
Old Sep 15, 2009 | 03:41 PM
dshakes's Avatar
dshakes is on a distinguished road
Jamie, whats that ducati lookin like nowdays?
Old Sep 15, 2009 | 05:31 PM
Hotbrakes's Avatar
Ok, here's some general numbers...Given a bike weighing in a 400lbs (I know its more) and a 200lb rider...
600lbs bike+rider, 110hp= power to weight ratio of 5.45
Rider loses 50lbs
550lbs bike+rider, 110hp= power to weight ratio of 5
Rider's 100lb girlfriend on bike
500lbs bike+rider, 110hp= power to weight ratio of 4.5
600lbs bike+rider, 130hp= power to weight ratio of 4.6
Conclusion- if you want 130hp just let your girl ride it...
Old Sep 16, 2009 | 03:39 AM
I could ride in
how many stock VTR's have 110 RWHP dyno verified...?
not many, if any, I'd say.
Old Sep 16, 2009 | 02:45 PM
It's just a yellow blur..... to everyone else. That thing is uber fast. It's harder to keep the front end down in second on that bike as it is in first on the VTR. Frankly, I like the idea of a 130hp VTR. I really think it would be a better overall bike.
Old Sep 16, 2009 | 03:39 PM
RCVTR's Avatar
I think 120 HP, with a set of light wheels and good suspension is th perfect VTR.
Old Sep 16, 2009 | 07:08 PM
I don't know about perfect, but that would be one heck of a good start!
Old Sep 16, 2009 | 07:38 PM
I agree, and am 5 hp away from that (nothing a rebuild with a set of OS JE pistons won't fix)
Old Sep 17, 2009 | 11:15 AM
tapatio's Avatar
tapatio is on a distinguished road
After GP Motorcycles replaced my ECU, airbox, and all four cams with '08 components (stalling issue, warranty work), my '07 1098 lifts under WOT in 3rd gear. 170 RWHP out of the 1098 is impressive, how did you accomplish that?
Old Sep 17, 2009 | 11:47 AM
I could ride in
a better question is can you best yourself on the street on a 1098 vs. well sorted 'hawk?
