I got one of these to try when I do the 520 conversion
Alloy carrier, steel teeth ring, & titanium pins - about $85 Should give good sprocket wear but lighter than full steel Heavier than aluminum tho but i prefer better wear http://www.drivesystemsusa.com/p/351...ket-honda.html http://www.drivesystemsusa.com/pictu...5/614625-1.jpg |
Can you simply replace the out ring when it wears out? Can you get in a couple different sizes for less than entire sprockets? I like the idea, thanks for bringing it up.
Hey internet tuff guys, new info comes up every time a topic is covered. The search function sucks. If searching was so easy, they wouldn't have created sticky's or white papers, so back off. Why waist your time posting a complaint, if you don't like the thread don't enter. New people join with new input. Ever try searching for the front end swap and find different information in every thread? People were posting in 2002, and had nowhere near the information we have in 2008. Get over it. |
Originally Posted by fundgh
(Post 159260)
(Post 159260)
Being steel teeth, when it's time to change the sprocket you would need a new chain & front sprocket anyway |
Take your own advice man.
well this time i noted the starting milage ( 38380 ) .... so i'll have a better idea how long the vortex sprockets last.
this set i went with a black cat5. http://www.pacifier.com/~trinc/images/vortex_cat5.jpg tim |
i've got the teflon coated one... but i'm not so sure i'm gonna do it. have to wait and see if my job ends up closer, lol!
What does this change provide? Faster acceleration or more top speed.
Better acceleration with no real penalty on top speed.
DOES THIS REQUIRE ALOT OF TIME TO CHANGE IS IT SOLD AS A KIT OR PIECES DO YOU HAVE TO REPLACE THE CHAIN? "SORRY BOUT ALL CAPS COMPUTERS AT WORK RUN THAT WAY"
Originally Posted by PRTSMN
(Post 161420)
CAN THEY BE CHANGED WITHOUT ALOT OF EFFORT. LIKE MAYBE A FEW HRS OR IS IT A PAIN IN THE A#@.
(Post 161423)
easily done in a few hours...even if it's your first time
FIRST OF ALL I WANT TO THANK ALL OF YOU FOR YOUR HELP AND RESPONSES. SECONDALY IS THERE A COST EFFECTIVE KIT THAT IS WELL MADE?
(Post 161427)
:nerd: |
I did the 15/43 set up a few weeks ago, lots of fun playing around. I just got back from the twisties with this set up, way to choppy, think I'm going back the stock front and +2 on the rear.
Originally Posted by TheRezyReb
(Post 161435)
Originally Posted by RK1
(Post 158690)
This is an interesting discussion, but I have a few questions;
What is the best motor oil for my Superhawk? What is the best rear tire for winning a race with my buddy and his 2006 Yamaha R1 LE? Should I install the Dynojet or the FactoryPro jet kit? What are the best slip-ons and which air filter should I use? Why would a guy from Athens keep insisting that "This is Sparta"? I mean come on, Athens is in Georgia. Everybody knows Sparta is in New Jersey. |
15/43 520 alum sprocket rear. great improvement in spinning weight reduction and acceleration. highly recommended to bring the hawk to life.
(Post 158690)
actually sparta is in Mississippi too.
whats the advantage of 520, other than lighter? is it just as strong or stronger? |
Originally Posted by justscoutin
(Post 214454)
(Post 158409)
Mac, I'm running stock 530 chain with 15/43 setup and love it everywhere but out on the interstates cuz it gets buzzy when you're in 6th gear at 75 mph where you'll be turning 5K rpm.
That's my 2 cents:draggin: |
installed 15F 42R this weekend and i must say this brought the bike to life. 5k rpm is about 75-78 mph now, not too buzzy to worry about for me
This is better than t.v.!!!
