Kai, I try to tell my wife about the my bike and she gives me the same response. LOL! All I can do is stare at it now cause there is all kinds of snow on the ground. What other mods have you all done?? I need all kinds of ideas.
Update? What have you decided to do so far?
Hi,
I´ve been reading with all the attention cause i´m in the same kind of obsession as you are. I´m into turning my 97 vtr to naked with a fat bar and keeping the cluster (it´s important to me to keep it). I recon this is a problem already cause the cluster is a big far from the bike front and might turned a bit uggly. This brings a doubht with the headlight, and what kind of it will be. Single, dual or with a windscreen. Personnaly i love the look of the speed triple with the dual headlight, but its a bit expensive and hard to put together with the cluster, as well as hidding the stock wires. It´s a hard job if you want to get it nice. Keep the news coming, i´m looking forward to see some pictures. |
another vote for the trail tech vapor
had this one on 3 bikes before i had to let it go with one of em. http://img169.imageshack.us/img169/3929/nt650.jpg http://img179.imageshack.us/img179/3929/nt650.jpg |
Well i havent got around to doing anything yet due to the late winter snow. I will post before pics as well as after pics of my naked project. I think im gonna just fab up a mounting bracket for the speedo and get some headlight mounting brackets and go from there. I was looking at the harness and there is a lot of extra length to the headlight which may be a problem to make it a clean look. As it is I will keep the posts updated and hopefully some pics as well. Any ideas on how to clean up the harness?
It will require a fair amount of trimming and the remainder can go inside the headlight bucket. Still working on mine, though. I'll let you know what I figure out.
Cool, any info will help and if for some reason I can help with what im doing I will.
^^^Do you have pics of your project? |
My excess harness is coiled up behind the steering head area and secured to the crossbrace in front of the airbox. Just make sure that it can't move to block the snorkel for the airbox.
The drawback was that I had to lengthen the gauge harness, but everything else ended up very clean and tidy. Kai Ju |
Kai,
what headlight brackets did you use to mount your single? |
Originally Posted by NakedOne
(Post 259487)
Nice Poppa, what exhaust do you have on there? How is the progress on the headlight brackets?
(Post 259730)
The headlight brackets should be done this week. My buddy picked up some scrap pieces of aluminum at work and just needs to weld them on. Truth be told, that should have been my first piece of advice...if you're not good at welding or metal fabrication, make friends with someone who is. Between my Jeep and bike my friend has saved me so much money. :cool: |
So last night was my first night ride and my current headlight situation sucks. What can i do to make my lighting brighter?
(Post 260028)
(Post 260028)
FYI the best rated prebuilt relay kit is: http://www.easternbeaver.com/Main/Pr...s/h4_kits.html
I just made my own, but it wasn't any cheaper, just no shipping time. |
I was looking at the aztec8 dual headlight kit that plugs into your stock harness. It claims that the bulbs are 55w x 2 so what would that do to the actual power draw and is that an actual safe way to change?
(Post 260106)
You´re doing very good questions. I´ve just ordered my dual headlights like those in aztec8, they will probabily be here in 2 weeks. And i´m having exactly the same questions as you are now. Keep them coming man. Does anyone knows what the 55w x 2 would do to the actual power draw and is that an actual safe? Plus, is it a plug and play work, or will we have to "eliminate" any wires? |
(Post 260106)
So I was checking on some relay kits and there all about $40-$50 bones. What is the cheapest way to use the dual light setup and get the correct light output safely?
(Post 260178)
lengths of heavy gauge wire, 2 colors: $14 2 Relays: $15 H4 plug: $5 Connector into stock plug: $5 6A diode to keep low beam on when High beam is on: $7 Solder: on hand So all in all I spent ~$46+ tax for a bulkier homemade version when I could have gotten a premade micro relay kit from Eastern Beaver for about the same amount. Now if you already have some thick wire and auto relays laying around you can do it for less. |
Nice, thanks for the info! Does anyone have any pics of the dual headlight setup on a stock harness?
