Swingarm Spools on a VTR?
Old Apr 10, 2006 | 02:16 PM
Yardstick's Avatar
Yardstick
I got some stands for cheap, but the rear requires swingarm spools. Has anyone added them and where did you put them?
Old Apr 10, 2006 | 02:26 PM
BooYeah's Avatar
BooYeah
Re: Swingarm Spools on a VTR?
If you check my "well i am back post" then you will see the ones i made with skateboard wheels and a big screw basically, i have used it to support just like a spindel and i like it.
Old Apr 10, 2006 | 02:35 PM
Yardstick's Avatar
Yardstick
That's almost what I'm looking for. I got aluminum spools with 8mm bolts with the stands. I was hoping someone might know a good place to tap into the swingarm to install them. I want to be able to use the stand to take the rear wheel off (for tire replacements mostly).
If there's not a good place or it's not a good idea I might be able to come up with a way to clamp a bracket to the swingarm and have the spools mounted on the bracket. It'd be more hassle, but I don't really want to do a bunch of welding or fabbing on the swingarm itself if I don't have to.
Old Apr 10, 2006 | 02:40 PM
BooYeah's Avatar
BooYeah
I am fairly sure you dont want to "tap" into the swingarm anywher. I think that it will hurt the integrity of the arm. But you might be able to weld it on, of make a braket like you were talking about.
Old Apr 10, 2006 | 03:05 PM
Yardstick's Avatar
Yardstick
I was thinking it might be meaty enough back where the chain adjusters are. Maybe not. I can fab up a set of removable brackets easy enough.
Old Apr 10, 2006 | 03:34 PM
BooYeah's Avatar
BooYeah
The one downfall of the hawk is how weak caparably the rear can be, or atleast IMO. Its not a bad arm buts not an RR arm by anymeans.
Old Apr 10, 2006 | 05:15 PM
icebud's Avatar
icebud
These are mine and I'm very satisfied of them.
And like you, at first I was afraid of doing hole in the swing arm!! But when I saw these rivo-nut and especially when I compared them to the anchor there's on the swing arm to hold the rubber chain guard, I saw that these are almost identical! Thus I was a bit more confident.
We make some test on a scrap swingarm and even with a 10 pounds mace, it was almost impossible to break these nuts, so after this, I was very more confident!
No problem until now!
Cia
Old Apr 10, 2006 | 05:24 PM
BooYeah's Avatar
BooYeah
So your having issues?? I am confused. Or are you talking about that they arnt there?
Old Apr 10, 2006 | 05:38 PM
icebud's Avatar
icebud
Sorry, maybe I miss my word on this!
I would like to say that since I've them on the bike, I had NO problem with them, but I only got them since a couple of weeks and the bike is still on the garage!!
On the other hand, I'm performing many mod on the bike these time and so, I put the bike on the stand, remove the bike from the stand, put the bike on the stand again, etc... which is a very good test IMO! and until now no problem at all!!
Hope it's more clear this time!
Cheers
Old Apr 10, 2006 | 08:29 PM
marmaladedad's Avatar
Hmm?
I had mine welded on.
Great...now that I need my Superhawk spool pictures, I realized I deleted 'em...
Old Apr 10, 2006 | 09:32 PM
Yardstick's Avatar
Yardstick
Any ideas how thick the swingarm box material is? I can check my engineering books to see if I can figure out what effects a hole like that might have on bending strength.
Old Apr 11, 2006 | 07:59 AM
Loco's Avatar
Loco
A hole in the middle of the metal won't do anything to adversely affect the structural intergrity of the whole piece. You really only have to worry when the diameter of the hole you are drilling starts becoming a significant percentage of the total width. Something as small as an 8mm screw or even 10mm won't be enough to change any functionality. There are plenty of factors of safety pre-designed into the swingarm, not to mention you are replacing steel with steel, and your bolt will inevitably carry some of the load that the swingarm is under. Thickness does not matter, it's hole diameter you need to be concerned with.
Old Apr 11, 2006 | 10:04 AM
RVO27's Avatar
RVO27
I'm having my swingarm braced with a brace from a 900rr and some spools welded on as we speak. It should be done tomorrow. I'll post some pics of the brace and spools as soon as I get the swingarm back from the fabricator.
Old Apr 25, 2006 | 08:05 AM
icebud's Avatar
icebud
Hey RVO, any news of your swingarm mod?
Is this have worked, got some pics?
Thx
Old Apr 25, 2006 | 10:22 AM
RVO27's Avatar
RVO27
Yeah, I got the swingarm back a week ago. Just been too busy to take some pics. I'll take some tonight and post them up. It turned out awesome
Old Apr 25, 2006 | 10:30 AM
icebud's Avatar
icebud
Glad to hear that it have worked!
Yeah, it must give the rear an awesome look
How much your welder have charged you to do this job?
Old Apr 25, 2006 | 10:40 AM
RVO27's Avatar
RVO27
I had the work done in Baltimore by Eastern Motorcycles Inc. owner Ross. He charged me $250 for transfering the brace and adding spool mounts (he is a great fabricator).
Transfering the brace took a little more work than first thought. You have to clearance the brake caliper side of the brace to allow the caliper to fit and slide with the rear tire for chain adjustment. The pictures will make it more clear after I post them.
Old Apr 25, 2006 | 03:36 PM
RVO27's Avatar
RVO27
Here are the pics
A little Dirty right now
Spools Welded on
Here is the Clearancing that had to be done to fit the caliper
A Few More Pics
Old Apr 25, 2006 | 05:32 PM
icebud's Avatar
icebud
Nice fitting and welding work!
I see the clearance problem you had with the rear caliper, nice solution though!
This is also cool for the spools, you will love them for sure, this is so practical! I still don't understand why Honda and/or all other brand are not putting spool on every sport bike swingarm? And please, don't tell me that cost is a problem!
Did you measure how much weight you add on the swingarm with this 900RR brace?
Old Apr 25, 2006 | 06:01 PM
superhawk22's Avatar
Hey RVO27, I'm going to be doing the same mod and had a question for you. Instead of cutting into the brace why not just use the caliper mount and mounting from the 900rr swingarm? Did you not have the parts or was it a problem?
Old Apr 26, 2006 | 07:50 AM
RVO27's Avatar
RVO27
I didn't think to weigh the difference, wish I had. I can't imagine that it added more than 3-4 pounds. When holding the 900rr swingarm in one hand and the superhawk swingarm in the other (before modifications) there wasn't that much of a difference.
I thought about doing that. But I didn't have the parts I only bought the swingarm on eBay. After talking it over with Ross (the fabricator) he said it would be no problem to clearance the brace and that it should not affect the rigidity much, if at all.
Old Apr 26, 2006 | 08:12 AM
I've got the parts,(ebay donor as well), so I'll try it the other way first. If I run into problems I'll try it your way, thanks.
Old Apr 26, 2006 | 09:52 AM
RVO27's Avatar
RVO27
Let me know how it goes. I'm interested to know how it turns out.
Old Apr 26, 2006 | 10:22 AM
icebud's Avatar
icebud
Yep! I'm also very interested to know how this will turns! Could be a very cool mod... for next winter, I've too many in progress for now!
Hey RVO, as soon as you have picture of the swingarm on the bike, post them also please!
Cia
Old Apr 26, 2006 | 10:25 AM
RVO27's Avatar
RVO27
Cia
Will Do
Old Apr 26, 2006 | 02:01 PM
Will also do.
Old Apr 27, 2006 | 06:51 AM
jschmidt's Avatar
jschmidt
Seems to me the issue wouldn't be the hole, it would be whether the thickness of the material (threadable depth) would support the button load.
Old Jun 9, 2006 | 10:48 AM
RVO27's Avatar
RVO27
I know it's been a long time but I finally got my swingarm powder coated black.
It's a bad picture, I know. I'll get some better pics up soon. Also some pics as soon as I get it on the bike. I'm still in the middle of painting the plastics. Hopefully that will be done in the next week or so. I'll update as soon as things happen.
P.S. Here's a preview of the paint job
Old Jun 9, 2006 | 03:51 PM
NOrrTH's Avatar
Have you seen the swing arm that is braced from underneath? There's a pic in my gallery
Old Jun 18, 2006 | 07:28 AM
altosuperhawk's Avatar
Here's what I did to use spools. Took a 15 inch piece of 1/2 inch bar stock that would pass though the rear axle- after the final 2 inches were turned down to pass through the smaller diameter left side of the axle. Press fit and permanently secured a spool to the right end. Drilled a small hole for a hitch pin in the smaller diameter left end. Pass the rod through the hollow axle until the right side spool buts up against the right end of the axle. Slip the other spool on the left end and secure with hitch pin. If desired the left spool could be permanently affixed to the left end of the axle if I didn't want to remove the rod. Much more secure than resting the PitBull round, serrated pads under the swing-arm which had a tendency to 'walk' forward if any kerosene or chain lube remained on the bottom of the arm. No drilling into the swing-arm and no permanent mods.
