SuperHawk Forum
-   Modifications - Cosmetic (https://www.superhawkforum.com/forums/modifications-cosmetic-34/)
-   -   Replacing rectifier (https://www.superhawkforum.com/forums/modifications-cosmetic-34/replacing-rectifier-33994/)
consulhammer Jun 8, 2016 06:24 PM
Replacing rectifier
When replacing with a mosfet rectifier, is it necessary to keep the mounting bracket from the original? The holes line up with no problem without it. Why is it there? Some sort of heat buffer?
Wolverine Jun 8, 2016 07:29 PM
What bracket are you referring to?
http://api.viglink.com/api/click?for...k%20Forum&txt=
https://www.superhawkforum.com/forum...er-swap-14380/
CruxGNZ Jun 8, 2016 08:03 PM
I've seen that "bracket" you speak of. It is more like a heat sink for the original R/R. Just toss it in the bin and drill new holes for the new R/R if needed.
