Radiators on the superhawk....
Old Apr 18, 2010 | 08:52 PM
ebbhead's Avatar
1998 superhawk mods.
ebbhead is on a distinguished road
Maybe a silly question, but was curious if the outside of the radiators that shows through the vent of the hawk, can be painted? Or is it hazardous in some way.
Old Apr 18, 2010 | 09:01 PM
nothing's Avatar
ride it out
it's not hazardous but their efficiency of radiating heat will be decreased as soon as you paint them. you could always just paint the grille that sits on them and not the actual radiator itself.
Old Apr 18, 2010 | 10:19 PM
Yes, its hazardous. These bikes barely cool themselves as it is & it all depends on the heat exchange of the thin-walled radiator fins. Painting them would be knocking a huge amount of efficiency off them. It would be about as smart as painting your tires. They are functioning units, not cosmetic.
Old Apr 19, 2010 | 05:17 PM
shayne's Avatar
It will reduce efficiency, so not a good idea.
Old Apr 19, 2010 | 09:55 PM
The radiators on my '05 are painted black from the factory... it cools just fine.
Old Apr 20, 2010 | 12:13 AM
shayne's Avatar
Yes, the factory ones are no problem. But spraying paint on the silver ones is not a good idea, as it will close up the cores a bit.
Old Apr 20, 2010 | 02:52 AM
fpalbrecht's Avatar
fpalbrecht is on a distinguished road
There is a screen on the outside of the radiator. I've painted it with high temp paint and it looks good. Doesn't effect the cooling because the actual radiator is still stock. Got the idea from a friends VFR. Their screens are black.
Old Apr 20, 2010 | 03:40 AM
luis saleiro's Avatar
luis saleiro is on a distinguished road
I´ve painted mines black and had no problems with temperatures.
They´ve been repaired.
The temp gauge works like always.
Old Apr 20, 2010 | 06:57 AM
swaptrex's Avatar
swaptrex is on a distinguished road
I'm gonna be painting mine in a couple days, just the grills, and outer edges.
Old Apr 20, 2010 | 07:43 AM
supermarto's Avatar
I know that there are compounds that do not put a layer of anything on aluminum, but they do "age" it and patina it dark, almost black. How about that?
Old Apr 20, 2010 | 04:37 PM
shayne's Avatar
Sounds like it would be ok.
Old Apr 21, 2010 | 05:47 AM
supermarto's Avatar
Can't say for sure what the durability would be on a radiator, but this is what I had in mind: https://www.birchwoodcasey.com/store/antiquing.html#oxd
Can't hurt to call them and ask about it?
Old Apr 25, 2010 | 01:13 PM
sweetriden76's Avatar
Captain Chaos
sweetriden76 is on a distinguished road
painted mine black, doesnt run any warmer than usual, and Im installing a digital temp gauge so I'll be able to get exact numbers in the near future...
Old May 12, 2010 | 09:21 AM
alientestsubject's Avatar
Fading Fast
alientestsubject is on a distinguished road
Your much better off not doing it!
Old Jun 7, 2010 | 09:54 PM
demartinoink's Avatar
not first your last
demartinoink is on a distinguished road
i'm new to the motorcycle world, just got a '99 vtr.
HEAT kills power and in that regard, anyway to run cooler is more effective and or more ideal operation.
Had my 300awhp daily WRX header/up/down pipes coated, and wrapped. under hood heat temp dropped, enough for the temp gage to register the lower temps. after running it around town & freeway driving, i could pop the hood at a gas station and the manifold and intercooler pipes would be cool to the touch.
you guys might want to look into: http://www.hightempenginepaint.com/
flyingeyepro
May 9, 2009 05:56 PM
superhawk205
Dec 16, 2008 06:52 PM
sempar paratus
Jun 12, 2008 08:44 AM
darylward
Jan 29, 2008 03:27 AM
redman
Dec 11, 2007 10:32 AM
