Powerbronze Lower Pics
well I have to say $300 well spent... I recently got a sharkskinz lower and was a little turned off by the fact that it was fiberglass and also that it only mounted by me 2 rear fairing bolts and 1 metal bracket... So i decided to get the plastic powerbronze lower... its a 2 piece unit and has 5 mounting points... the brackets were well made and it fit perfect... very easy to install, heat shielding was already on it... it came gloss black " I will be painting it red"... It makes the bike and the quality is very good so dont hesitate so scoop one up... Ill take more pics later in the week.............................. http://i896.photobucket.com/albums/a...ps789d233c.jpg
Where did you order this from?
1 Attachment(s)
You might want to get a cone cutter and make a hole so you can read you oil level easy. I made mine big enough for a grommet that caps it off.
Attachment 23508 (:-}) |
Originally Posted by Northman69
(Post 354014)
(Post 354014)
| All times are GMT -7. The time now is 04:41 AM. |
