Melted Flush Turn Signals
I installed some flush signals (I think they are EMGO?) last week. This morning while warming up the bike I noticed they were loose and tried to tighten them and they just pulled out stetching about 4" long :shock:. Maybe I should have hooked them up for two wire opperation? :oops:
They worked fine all along?
Sounds like something short curcuited inside.
Pics would be good.
They still work but I have them hooked up as running lights and turn signals. I guess they couldn't handle the heat of the lamp on all the time.
Was this a mod or were they designed as a running light model.
It's a three wire turn signal. On, flash & ground.
If I remember right the turn signal bulb is much brighter than the running light .
Sounds like you have the wires switched so that the turn signal is running all the time which made it too hot and melt. |
1 Attachment(s)
Here's a pic.
Originally Posted by SuperLoud
(Post 54030)
Originally Posted by spdrcr
(Post 54035)
Here's a pic.
| All times are GMT -7. The time now is 12:48 AM. |
