led bli
variable 2 pin flasher relay wiring
the one i purchased is a 2-pin variable relay, the original relay is a 3 pin, the blinkers work with the old relay but flash very fast, I'm thinking the new variable relay needs to be wired into the harness so I can adjust the indicator flash speed, just not sure were to wire it in any thoughts.?
The PO of my bike spliced in the LED indicators but kept the original relay.
This is the replacement one i purchased: It has only 2 wires but was plug and play and the LED indicators flash regular speed now.
Yeah, not sure about the adjustable one.
