Best front turn signal indicators?
What're the best front turn signal indicators? I had the LP kind that look like cab lights on a semi rig, but they broke. Now I have the large LP flush mounts, but they are awefully big and don't match the curve of the fairing. Anyone found a higher quality light that looks good? I see that www.devilbikes.com has some expensive ones, but I havent' heard anything about them.
I like the LED ones from Shock Racing. I have them on my 1000RR and wife's 600RR.
I have LP flushmounts on the front of the VTR. Had to cut some off the back side then take an old pan, stick in on the stove, and melt the end again to get the inside lip so the light socket will have something to grab. You have to trim the threaded outside part so the big plastic nut will go on. These are true flush mounts and the lenses along with the foam gasket seal the fairing quite well.
Here are a couple...
1st and 2nd photo from Watsen Design $135.00 (Canadian) http://www.watsendesign.com/Honda_Pr...a_products.htm
3rd photo LED Turn Signal from Aparila SVX Motard about 25.00 From Moto International.
I just ordered a set of the Watsen's signals. They are $$$, but as soon as i saw them i knew i had to have them. Someone on this forum had pictures of some mounted on a blue SH, and they looked fantastic. I'll try and find the thread and steer you to it.
I just picked up 4 of these and I'm waiting for my undertail to show up this week to install the set. I'll have pics up as soon as I'm done installing everything.
www.rizoma.com
www.rizoma.com
Here is the thread with pics of the Watsen turn signals
https://www.superhawkforum.com/forum...ead.php?t=2331
Hope this helps
Hope this helps
