VFR Clip-ons VTR
http://i23.photobucket.com/albums/b3...e/P1010011.jpg
VTR on the left
VFR on the right
http://i23.photobucket.com/albums/b3...e/P1010012.jpg
http://i23.photobucket.com/albums/b3...e/P1010013.jpg
http://i23.photobucket.com/albums/b3...e/P1010014.jpg
had to undo brake line split mount screw
much improved touring riding position, and improved turning response and control.
VTR on the left
VFR on the right
Hi intoxxx, nice job!
Did you have to reroute throttle cables, or have any clearance issues with the fairing/tank? Which year VFR are clipons from? I was under impression that there are some clearance issues that need to be resolved with VFR clipons...
Did mine a couple of years ago w/ VFR bars and did have clearance issues with the fairing. Specifically, interference w/ high/low beam switch on the left and kill switch on the right - THAT'S THE SCARY ONE! I ended up removing about 1/2" of the fairing above and in front of the bars and repainting the front fairing. It is a great improvement though. The seat also needs to replaced cause it sucks.
only thing removed was the brake line mount screw by the split. it had to come off to allow the extra height. two twist ties secured it, one to the old mount screw, one to the instrument panel bracket.
clip-on's i found on ebay from a salvage stripper/re-builder in Wisconsin.
1996 HONDA VFR 750
only clearance issue is on full lock either way, fingers hit fairing, and starter will hit tank. add some washers with gorilla glue to the ends of the locks till you have the proper lock clearance.
I have run vfr bars for several years, 94-97, and have no issues with clearance unless all the way to lock. Then controls touch fairing, but how often do you go that far ?
1996, aftermarket, clip, clipon, clipons, cluster, ebay, forum, hondavfr750, instrument, modify, ons, superhawk, vfr, vtr, vtrsuperhawk
