VFR Clip-ons VTR
Old Mar 8, 2011 | 02:30 PM
intoxxx's Avatar
haha yeah
intoxxx is on a distinguished road
Lightbulb VFR Clip-ons VTR
http://i23.photobucket.com/albums/b3...e/P1010011.jpg
VTR on the left
VFR on the right
http://i23.photobucket.com/albums/b3...e/P1010012.jpg
http://i23.photobucket.com/albums/b3...e/P1010013.jpg
http://i23.photobucket.com/albums/b3...e/P1010014.jpg
had to undo brake line split mount screw
much improved touring riding position, and improved turning response and control.
Old Mar 8, 2011 | 05:39 PM
dannyz's Avatar
dannyz is on a distinguished road
Hi intoxxx, nice job!
Did you have to reroute throttle cables, or have any clearance issues with the fairing/tank? Which year VFR are clipons from? I was under impression that there are some clearance issues that need to be resolved with VFR clipons...
Old Mar 8, 2011 | 06:06 PM
BluStreak's Avatar
Did mine a couple of years ago w/ VFR bars and did have clearance issues with the fairing. Specifically, interference w/ high/low beam switch on the left and kill switch on the right - THAT'S THE SCARY ONE! I ended up removing about 1/2" of the fairing above and in front of the bars and repainting the front fairing. It is a great improvement though. The seat also needs to replaced cause it sucks.Name:  DSCN0368.jpg
Old Mar 9, 2011 | 01:34 PM
intoxxx's Avatar
haha yeah
no sir, i didnt have to do anything with the throttle. didnt even take the cables off. the grip slides off the end of the old clip-on and right onto the VFR's.
only thing removed was the brake line mount screw by the split. it had to come off to allow the extra height. two twist ties secured it, one to the old mount screw, one to the instrument panel bracket.
clip-on's i found on ebay from a salvage stripper/re-builder in Wisconsin.
1996 HONDA VFR 750
only clearance issue is on full lock either way, fingers hit fairing, and starter will hit tank. add some washers with gorilla glue to the ends of the locks till you have the proper lock clearance.
Old Mar 10, 2011 | 06:02 PM
slo1's Avatar
slo1 is on a distinguished road
or use stick on wheel weights
I have run vfr bars for several years, 94-97, and have no issues with clearance unless all the way to lock. Then controls touch fairing, but how often do you go that far ?
Hangfly
May 14, 2015 03:57 PM
Blackbird
Jun 30, 2013 03:18 PM
Crashrat
Nov 28, 2009 05:10 AM
andy9743
Sep 7, 2007 12:18 PM
VTwin996Rider
Nov 2, 2006 04:41 PM
