2 Attachment(s)
Hey man,
Really cool bike you are assembling and I am stoked that it is being built in the NW! I love everything except for the can and the tank and tail are genius. I have seen that technique performed on the tank before but not with excellent results. Here is a bike I built a few years ago that resides in seattle. Attachment 28023 Attachment 28024 You can see the style of exhaust I like... Heh |
Nice looking bike there. I take it you no longer have it.
As far as the can is concerned, it is just about the easiest part for me to change my mind about and switch. I think once the whole bike is assembled and finished it wont look as goofy. JMHO for now. If things don't look right I am not against changing things. So I ordered all my parts today. It hurt a little looking at the amount. I bought tires front and rear, a new chain, and four pod filters. Still I am on pace to keep the amount spent for everything bike included at $1100. |
$1100 well spent.
what kind of tires can you/did buy ? tim |
Originally Posted by trinc
(Post 250267)
$1100 well spent.
what kind of tires can you/did buy ? tim Also ordered myself some exhaust wrap. So other than fork seals the parts are done being bought. |
Engine work
2 Attachment(s)
So I found the kick start seal is done so its back to the dealer. I have been taking off covers for cleaning and inspection. Here are some shots.
Attachment 28014 Attachment 28015 |
how did the bottom of the pan look ?
tim |
(Post 250402)
tim |
Whoops....theres my bucket of used oil in the background....lol
Ill give you $1200 for the bike when its done. And you have to deliver it. :) |
Originally Posted by Springbubba
(Post 250423)
Engine painted!
2 Attachment(s)
Yep, its painted, and basically polished. I have the stator cover to polish then I need to hit all the shiny stuff with a good final metal polish and that is a wrap. The pictures say it all IMO.
http://i703.photobucket.com/albums/w...ectcafe182.jpg http://i703.photobucket.com/albums/w...ectcafe183.jpg Attachment 28012 Attachment 28013 |
lookin good.
Originally Posted by cornandp
(Post 250254)
Naaaaa it is still mine.... I am attending university in So-Cal and only wanted to take one bike so the KZ stayed. |
time to reassemble ! you must be really jazz'd.
any word on the paint ? i'll have to swing by again soon. tim |
I will ask about the paint again today. You should stop by in a week or two, by then I should have it 90% or better reassembled. Considering I still need to paint the rear rim, then have the tires mounted. Also need to service the forks. Those are the more major things to accomplish.
I was pleasantly surprised on saturday when I went to the dealer, not only did they have my fork seals in stock but they also had the kick start seal! That saved me some time since now I don't need to wait a week or more. I pulled the starter out and sealed off the opening. No reason for me to have it there since I dont have the wiring, the switch, or the solenoid installed. I figure it dropped about another 5 pounds off of the bike. I will have to bring two scales in and weigh this thing dry, I am curious as to the actual amount of weight reduction. |
So today I was able to paint the rear rim, and also I was able to install the motor, the swing arm and the lower triple tree. I don't have any pics from today though.
WE WANT PICS, WE WANT PICS, WE WANT PICS, ETC.
Keep this worked up CNP. I think you have something that is inspiring in your recent project. It's a great work and it's worth moving forward - a fine example to others. It's also worth completing. Move ahead and Godspeed.
Thanks Nuhawk, it will be finished I promise!
Back ordered parts may slow the rebuild. My tires and chain are back ordered go figure. I will post up a few shots of my progress later today.
2 Attachment(s)
So good news, the tank and cowl are now primered up, the guy painting it says he should have the pearl white on it this week. When he does I will try and get a shot for everyone before the stripe goes on.
Lookin' great!
1 Attachment(s)
Started taking the forks apart, eyuck it was bad looking oil. Looked like it had separated. Anyways I polished the fork end and painted the tip. Heres what it looks like.
Attachment 27996 |
1 Attachment(s)
Well both forks have been serviced with new oil and seals. Later I will put the headlight brackets and clip on's on and its beginning to look like a motorcycle. Bring on the tires!
Attachment 27992 |
Haha, I love the fins on the oil filter
1 Attachment(s)
Where did you get the mirrors?
Originally Posted by VTRumble
(Post 251029)
Electrical
2 Attachment(s)
Yep, gotta sort the electrical now. Its a little bit of a project considering I dropped a whole switch assembly that used to be the throttle assembly. See I shortened the throttle holder so it would fit on my bars, this got ride of the hi low headlight switch the kill switch and the starter button. So now I have to bypass all that stuff, so the headlight will skip the switch and the kill switch needs to be bypassed too.
Attachment 27985 I also am having to make battery hook ups since the battery is all the way in the cowl. So I made a new frame grounding point and new positive lead that will get hardwired into the original harness. The trick with everything is to not see it, still working on that but I don't think I should have trouble accomplishing that. Attachment 27986 |
At some point it is easier to start over and not use the old harness at all.
