My Cafe Build
4 Attachment(s)
Hi all,
So I recently purchased a 1972 CB 500 to turn into a cafe racer. I wanted to stay true to the original concept of a cafe bike. Meaning a budget build all the parts I can build by hand will be built by hand. Like the clip ons exhaust, seat, seat cowl, modify the tank, move the rear sets, and on and on. I will not buy any parts unless there is no way to build them. I know alot of people buy the parts for these bikes then assemble but I thought it would be cool to do it all myself. It may take longer but should be fun. As I go I am sure your opinion will help me with the direction of the build. Attachment 28754 Bike in the VW Bus, this is what she looked like when bought for $500 Attachment 28755 I repaired, repainted and recovered the old seat so I could sell it on ebay for some extra money for the build. http://i703.photobucket.com/albums/w...ectcafe012.jpg Attachment 28756 Here are the newly made clip-ons Attachment 28757 I will keep posting as I build, in case people want to see, let me know what you think. |
Awesome project. Those bikes make great cafe racers!
fun! keep the pics and updates coming.
Nice bike, I'm in for the duration:)
i love cafe builds, in!
So here's some of my to do list.
Move battery to under the rear cowl Move electronics to under the seat Remove all mounts Cut and modify rear frame Remove center stand Build Front fender Build rear hugger Build Rear Cowl (Aluminum?) Build Tank (Aluminum?) Move back rearsets and controls So things I would like opinions on are, should I build an aluminum tank and cowl or just modify the original tank and make a cowl out of steel? One or two gauges? What style for the exhaust (High mount, Gp Mount under the cowl etc.)? |
2 Attachment(s)
Got some practice in with the english wheel. I am going to build my fenders among other things.
Attachment 28752 Attachment 28753 |
I think everything on your mod list is achievable but I question the tank options. I think you leave one out. I might opt for cutting the tank and then fabricating a transition band in your shop. A friend of mine just chopped his Harley tank and the result not only holds gas but is really cool. He cut his vertically for his downsize but I can imagine a horizontal cut for more sleek design.
1 Attachment(s)
(Post 231025)
I like that too, here is the concept I am drawing a number of q's from. I am not going to copy it but the overal sleak look is what I like. Attachment 28750 only difference is I may try and make a similiar tank from aluminum except maybe with some clip on cut outs in the front. |
I do some work for a guy who has one of these.
http://www.bikeexif.com/wp-content/u.../03/ajs_7r.jpg I love the tank on the bike above, well, I pretty much love the bike. |
(Post 231034)
3 Attachment(s)
been fiddling with the bike today. Removed the battery tray, and started working on the headlight and gauges mounting locations.
Attachment 28747 Here the headlight bucket after sanding out some scuffs Attachment 28748 And this is after painting it http://i703.photobucket.com/albums/w...ectcafe022.jpg No more destroyed bucket and gauges off Attachment 28749 So this is what I am thinking as far as a gauge placement. Opinions? |
2 Attachment(s)
Wow looks to be in really good shape to begin with. That's an awesome idea. That concept bike is REALLY nice. You've got good taste, stick with that basic idea and you can't miss. Too bad Honda doesn't build anything like it ala the nightster. Here's a '73 CB350 I picked up for $200 and fixed it up my way.
no gauges. just an opinion.
captain, how long did you spend to get that 350 done?
Autoteach, I want at least one gauge for reference so for the street the speedo and for track use switch it for the tack. I am not sure if that will be the gauge I will use though I may find a replacement that is in better shape. |
I don't even remember. I guess I owned to for about a year but I wasn't working on it everyday. LOTS of cleaning but it was really cool because it only had around 5k original miles and hadn't been registered or titled since like 1975. It came with the original title from brand new. I basically kept it stock besides removing stuff like the fender, tailight, signals, chainguard and stock exhaust. Put on an aftermarket set of carbs (duh, they cost more than the bike) too.
http://home.ama-cycle.org/post/showp...bonnie_600.jpg
My boss has a boldoro endurance tank, an airtech cr tank for the 750, and a stock one if you are interested. The other idea that came to mind is if you are going to make your own tank, inset the guages flush in the top. That way the bars stay clean. |
Andrew, I can't believe it cause I had a 72 500-4 w/ Borrani pipes and Clubman clip-on bars (34 years ago). Painted my tank "flip-flop" black, which looked kind of dark purple metalflake in bright light. I would think being a cafe "racer," you'd certainly wanna leave the tach on the bike, at a minimum. I think black w/ chrome fenders would be perfect for your project.
I envy your talents, please keep us in the loop as you progress! Did you get my ? on modifying my tail rack for a Sargent Seat? |
[quote=autoteach;231119]http://home.ama-cycle.org/post/showp...bonnie_600.jpg
quote] :eek: quite the cluster. I might consider the gauge in the tank, that would be pretty trick, but it also would be hard to see. Oh the compromises/ dilemas. Bluestreak I sent you a visitor message just let me know. |
I like your idea of an aggressive pair of clipons cut into the tank matching the leg reliefs in the rear. Really like the top curveture of the tank with this look. Ah, to gauge or not to gauge. Either is optional and viable but I think the difficult part is if you chose to gauge the infinite number of parts available - usually all mail order - make this a huge research project to get the right look.
Originally Posted by nuhawk
(Post 231141)
Also does anyone know what I need to do to run this bike without a battery? |
3 Attachment(s)
So here are some things done today.
Attachment 28743 Start from flat plate Attachment 28744 and end with this, if I keep it I will polish the aluminum out. Attachment 28745 Here is where the headlight will end up roughly. |
CB200 tanks have a nice cafe look. Put one on a SL350 roadracer.
So I have a couple of questions for anyone who might know.
What do I need to do to run without a battery? Can I drill a hole pattern into the front rotor without causing problems? Any answers would be awesome thanks. |
Looking real nice! Reminds me of my first street bike - a '73 CB500F that I bought for $50 in 1991 and took my road test on.
1 Attachment(s)
I started out on a cafe bike as my first bike. I then moved up to my SH. I loved them both but the cafe was just too small for me after learning how to ride.
Here they are together. Nothing more fun than fixing a bike up. Attachment 28719 |
yeah small is an understatement these bikes feel like toys. Weigh right around 400 pounds wet I think. I am trying to loose 40 to 50lbs off it because I am considering taking it to the track possibly to race it in vintage class eventually. I haven't done much to it in the last few days. I am waiting for aluminum foot pegs then I will move the rear sets. The stockers weigh an easy pound or two since the mount is solid steel. The plan right now is to make the exhaust under engine keeping its CG down. Still need to know if you can run it without a battery.
if you aren't too far into the project yet, this is still available on ebay.
I was outbid about 12K ago :) http://cgi.ebay.com/ebaymotors/Honda...#ht_500wt_1182 |
Originally Posted by cliby
(Post 232075)
