the madness continues
Old Apr 8, 2009 | 10:02 AM
hawxter996's Avatar
ole dirty bastard
I need professional help!
Old Apr 8, 2009 | 01:21 PM
Malice's Avatar
Cool, can't wait! Man that suede black with red frame and wheels looks awesome!! I may just have to change the look I'm going for on mine when I get my lower fairing
________
Vaporite Solo Deluxe Vaporizer
Old Apr 8, 2009 | 01:37 PM
Derbig Mooser's Avatar
Derbig Mooser is on a distinguished road
That powder coated frame is spectacular! Better looking than a new red-framed Duc Monster I saw at the dealer's this week.
Can't wait to see it done!
Old Apr 8, 2009 | 09:25 PM
Malice's Avatar
Hawxter,
What diameter tubing are you using for your exhaust? I'm planning on doing a custom exhaust, among other things, and can't find and info on the diameter for stock or aftermarket. Thanks
________
Mb50
Old Apr 8, 2009 | 10:37 PM
supermatt996's Avatar
supermatt996
supermatt996 is on a distinguished road
liked the way you turn the bottom brace on the subframe upside down. and the single radiator
Old Apr 9, 2009 | 02:32 AM
Malice's Avatar
Thanks!
________
Cat Wheel
Old Apr 10, 2009 | 09:51 AM
Can't get over the powder coating on the frame! Frabjous! I would say the VTR engine is much better looking than the Suzuki V-twins.
Old Apr 10, 2009 | 11:33 AM
zmaniv's Avatar
thanks guys.
i will be updating this,my wife is in the hospital.
reconstructive surgery of her stomach and esophagus.
doc says surgery was long and difficult,but she is doing well.
Ouch hope everything goes well
Old Apr 10, 2009 | 07:49 PM
alive226's Avatar
Best wishes to your wife for a speedy recovery. Oh and the bike looks great can't wait to see it done.
Old Apr 11, 2009 | 03:07 PM
RCVTR's Avatar
Best wishes to your wife for a fast and full recovery!!
Old Apr 11, 2009 | 03:21 PM
all the best, man! How's that new grandbaby doing? Mine just had his first b-day. Your build has had a huge following so post when you can.
Old Apr 11, 2009 | 11:31 PM
Malice's Avatar
she is full of energy and has her grandfathers appetite.
Ha ha ha...that's awesome
________
Headshop
Old Apr 13, 2009 | 09:29 AM
Here's hoping for your wife's full and fast recovery. Best of luck to you.
Old Apr 13, 2009 | 09:31 PM
supermatt996
what did the radiator come off of i was looking into doing the swap
Old Apr 13, 2009 | 11:05 PM
98SoopaHawk's Avatar
98SoopaHawk is on a distinguished road
odd, my friend named her daughter nevaeh as well, and when she sent me that on AIM, i realized right away it spelt "heaven" backwards
Old Apr 14, 2009 | 10:40 PM
supermatt996
Matt
it is a cbr600rr 2005 model,with mods.
by mods do you mean notching the top for clearence? I know that 2 wheel tuner did a low budget hawk streetfighter build but i cant find the pictures on their new website. why did you go with the 600rr radiator instead of the stock one turning clearence? or just the better look and were are you going to put the oil cooler? also by flipping the bottom brace on the subframe upside down did it relocate the rear passenger pegs?
Old Apr 15, 2009 | 08:36 AM
unable to open the pic.... (oops, pic no longer posted... doh!)
Old Apr 15, 2009 | 08:59 AM
can you re-post the pic showing the braces you added? please....
Old Apr 15, 2009 | 04:02 PM
Today my beautiful girlfriend once again astonished me with her brains... It happens quite often you know...
Her usual aptitude for mechanical things is along the lines of putting gas in the car... But she has a way of seeing the core of a problem...
I have been trying to sell off the SP1 swingarm to another local VTR owner, he likes the idea but is a bit nervous of having it welded to bolt it up, so that was put on hold until I could figure out another solution to the bottom link...
As I was sitting there mumbling about it, my gf said to me "Why is it a problem... You already have that triangular thingy..." pointing to the link...
So I tried explaining that on the RC it was like that on a VTR it was a plate on the outside of the bearings... To which she replies, "so weld that part (meaning the one I had welded to my swingarm) to the triangle plates then... Instead of the swingarm... Then the arm is unchanged..."
So I explained that steel and aluminium wont work to weld together... Her response... "So bolt them up then..."
I tried explaining that I already thought of that and since the parts arent the right shape (cast aluminum, with ridges and stuff) it wont work either...
She just rolled her eyes at me... " So make a new aluminium piece then... You made all that other aluminium stuff..."
Damn... She got me... Why didn't I think of that?!
So short version... A triangular aluminum block with three holes... One to press in the bearings scavenged from the stock link, and two for bolting on two steel plates forming the other two ends of the triangle...
The block remains the same and you can change the plates and the holes in them as much as one would want to play with ratios, just as with a plate only setup... The good part is that the swingarm remains untouched, a true bolt-on solution...
Old Apr 15, 2009 | 04:36 PM
The annoying part is that she has most of the family as witnesses... I'm not crawling out of this hole in a while...
I didn't have my camera with me... But I'll get pic's next time I'm at my parents (garage and tools are there)
Old Apr 17, 2009 | 11:31 AM
Radiators can also work well under the seat, if air-flow is managed right. It's a natural low-pressure area, and Britten (I think) used to mount the radiator under the seat with some ducting and vents to facilitate airflow, and a fan.
And it will make the front-cylinder area cleaner, and give lots of front-tire clearance.
Old Apr 17, 2009 | 06:12 PM
Malice's Avatar
I think I'll steal the carbon fibre carb plate idea
________
VAPORIZER GUIDE
Old Apr 17, 2009 | 06:15 PM
Malice's Avatar
Even though I prefer brighter colors on my bikes I may also steal the red frame/wheels with the suede black paint too. Mine is going to have a one off full fairing though so it'll still be different than yours. Hell maybe I should save myself a lot of work and just steal your whole bike and make a fairing for it
________
Vaaapp
Old Apr 18, 2009 | 01:36 PM
alive226's Avatar
I love the cat's leg in the top of the picture. It makes those guns seem even more fierce.
Old Apr 23, 2009 | 07:06 PM
supermatt996
where are you going to put the battery now that the height under the seat is narrower
Old Apr 24, 2009 | 05:37 AM
Those are sweet batteries (although they cost about as much as carbon stacks, lol)
Old Apr 24, 2009 | 07:15 AM
the fact that they are made from carbon is a moot point (material choice is truly a secondary issue) , but the dimensions (flow bench developed) which help produce a gain of 5 hp in the mid-range will (for some of us anyhow)....
Old Apr 26, 2009 | 01:26 PM
Malice's Avatar
What's the life span on a speedcell?
________
Essential vaaapp vaporizer
Old Apr 26, 2009 | 01:36 PM
alive226's Avatar
I love the red valve covers. Kinda of Ferrariesq
Old Apr 27, 2009 | 12:08 PM
Malice's Avatar
its actually duplicolor chevy orange.
i think i may stick with it as a kind of signature.
And all this time I thought it was red. I guess I should check the color settings on my monitor.
________
ChyarasPussy
