Jet kit Needle question
alright, so the little clip on my needle broke, and i was finally able to get a new clip. Well, my question for yall is, which little notch on the needle does the clip go on? The jet kit was installed by the previous owner so i have no instructions. Your help would be GREATLY appreciated! Thats the only thing holding me from riding right now, haha. thanks!!!!
Re: Jet kit Needle question
can someone please help me out here. I want to ride today, but i cant. Or please atleast tell me where to go to find this information, thanks
That's because there is no correct answer for you. It depends on your setup. I'm running a dyno-jet kit and it called for #4 but it ran MUCH better on #5 with my 2Bros Ti-highmounts. I'm now back at 4 with some RC51 pipes.
Your anwer really is only 3 cap screws away. Remove the needle assembly from the other carb and see where it's set. Unlike the jetting, the needle position is the same on each carb. |
haha, yeah, thanks. The other three screws are pretty difficult to get at though. O well, thanks for the info
not hard to get at, just have to be smark. i just did this crap, and yes it is crap. to get to that bottom screw you have to undo the two bands on the front carb boot -the thing thats rubber that mounts the carb to the bike. pup it out of the boot and you can reach that bottom philips screw thats closest to the front wheel holding the diaphragm/needle assembly in with a RIGHT angle medium philips head. thats it. done . PITA to work around that support bar but its ok. gettin it out isnt hard.. gettin it in with the spring is. :?
Wouldnt it be easier to just pull the carbs and work on them out of the bike. Maby its just the fact that I had to do it 17 times to get the jetting right, but I can pull them change them and put them back on in less than 1/2 an hour.
sorry, chase, have to disagree. lot easier to adjust af screws in 30 seconds than 30 minutes with your method, if all you need is a flippin dremel tool and a steady hand to make a flat slot on screw head. ok fine, if you dont have a dremel and your worried blah blah. they make a tool to attach to the nipple housing and adjust without removing anything. now were happy :lol:
I agree if your messing with the Pilot Screw adjustment, but to get that dang needle and spring in or if your changing jets my big ole hands wont fit in that tiny compartment. but ymmv
Same as the other one.
Originally Posted by Chase
(Post 66956)
