Bike is ready to ride
Old May 7, 2017 | 10:56 PM
2wheel's Avatar
2wheel is on a distinguished road
Hello a few months ago began my journey here and with my new bike. When I was thinking of getting it I asked here for advice and ultimately decided to buy a 2003 wrecked Superhawk for a grand. It had also been left outside for over a year without a cover. it started and ran and the engine and gears seemed strong. After delving into it I discovered two things. There was a fairing stay that had broken off and left a hole in the frame. Also the bike needed ALOT of little things. Here is a list of all the things I have done so far.
-both fork seals and new fork oil.
-plugs
-cam clearance and timing
-Manual CCT, Had to do the timing because my cam chain slipped.
-new grips, throttle sleeve, mirrors, brake lever was bent.
-Changed out the headlight
-changed the R/R for a mosfet from a CBR1000
-changed out the integrated blinker tail light because it didnt integrate no more.
-changed out the thermostat and temp sensor (gauge still doesnt work on the dash, although I did ground the gauge for a second and it does work)
-Cleaned the carbs, put some easy access vacuum hoses for carb balancing, didn't even need to balance the carbs.
-trimmed the tail area
-re routed the seat release, you dont have to use the key there is a small pull lever underneath the seat now. My key was getting bent.
-Minor body work, the tank dent got bondoed and painted but I used a different shade, gotta fix tat.
-cleaned chain, still good.
-new fluids.
-cleaned a little rust
-needs brakes and a few other small things
The thing runs good now and I wanted to thank you all for your help. I havent decided what to do about the hole in the front but I cant really sell it without taking a huge loss or spend $300-$900 swapping the frame or finding a welder. Im gonna ride it for now. It has been an adventure and I couldn't not have done it without referencing this forum, so much good info here. Thanks!
I did this as cheaply as possible, I still spent around 500 bucks to get it to this state. By no means a show bike, just an every day ride!
My bike as it sits
Before I bought it
Old May 8, 2017 | 01:24 AM
Well done mate,
Now get out and enjoy it.
Old May 8, 2017 | 05:27 AM
Agree! Nice job, now get to know the bike and you won't be thinking of resell issues. They are very reliable machines when taken care of.
Old May 8, 2017 | 11:03 AM
Fastguy59's Avatar
Well done. If you can fine someone with a twisted frame to can cut out the part that broken on yours then you just need a talented welder to tig it back in place. Mind you the steering head bearings will then need to be changed. For now I recommend some gaff or duct tape and cover the hole as the back side of the bearing are susceptible to dirt entering through the opening...
Old May 8, 2017 | 07:01 PM
2wheel's Avatar
This bike is great, I love it. The torque is so nice for city riding and that's the majority of my riding. I love this bike!! The clip ons are too low for my liking though. The handling is great and it so skinny! My first bike was a Suzuki VX800 and that was a great albeit underpowered bike but I loved the low end and skinniness. The superhawk is like it's big better looking brother. My previous bike was a FZ1 and while it handled ok and the top end was screaming I just appreciate the superhawk so much more. I have found a bike that I want to keep for a long time.
Old May 8, 2017 | 07:02 PM
2wheel's Avatar
Hey thanks for the tips, I will be in the lookout for a twisted frame. This seems like the way to go.
Old May 8, 2017 | 08:57 PM
Hmmm. Apparently the hole left by crashing the faring stay is somewhat common. I would not have thought that.
https://www.superhawkforum.com/forum...sh-lever-5145/
Old May 8, 2017 | 11:01 PM
2wheel's Avatar
When I first discovered this a day after I brought the bike home I was absolutely crushed, a hole in the frame! I thought I was done but it is a common thing and everyone told me that it's not that bad, to ride it and it would be fine. I am probably going to get it welded at some point but it isn't the absolute disaster that I thought it was.
Old May 10, 2017 | 03:09 AM
ae29's Avatar
ae29 is on a distinguished road
i reckon hard putty and spray paint would conceal that hole
VTF1998
Jul 18, 2013 12:15 PM
CANADAVTR
Mar 9, 2010 06:59 PM
andrewlc77
Aug 20, 2006 10:37 AM
superhawk22
Jun 28, 2006 03:53 PM
102dals
Apr 25, 2006 06:00 PM
