Thermostat Hoses... again
Here I go again, I removed the PAIR, EVAP, and CAV systems off my bike and have figured all the lines I need to cap and plug BUT, The coolant line that is on the T-stat that faces aft just above the Temp Sensor.. uh, I dont know where it went. I have followed the manual and browed on here for a good while this morning and I dont know where I have gone wrong. Any help. Thanks.
That one goes no where..... if you look it is blanked off (the hole isn't drilled) ;)
WOW, just wow. Thanks for that help. I really cant belive that I didnt remember that from last time, or take note of it this time, or even look at the damn fitting. Ha, and I work on F-18s... Somthing wrong with me. Thanks!
They designed that part on April 1st
Ha! Yeah, they got me... twice.
Originally Posted by Squid
(Post 323463)
No worries but you do have to live with the fact an old jarhead pointed it out to you....... damn squids.... :rotf::rotf: It just one of those cost cutting things, Use the same basic casting for as many parts as possible. the same reason for the faux CCT mounting points on the cylinders. ;) |
Ha Ha, yeah... From the min I joined this site I wanted to try and keep an even playing field on the ol' navy vs marines... Dropped my guard and you caught me with my pants down :rolleyes:. Thanks for helping me out with that. I was racking my brain, I read the Carb and coolant system removal and install 3 or 4 times, looked thu older posts and couldnt find anything out on it. Now I know why. ;)
Originally Posted by 7moore7
(Post 323464)
(Post 323487)
I used your build thread to look for that non existant hose and it seemed to me that you took a pic detailed pick of everything other than the t-stat. Where were you man? :o. Everytime I look at your build it makes me want to tear into mine and Just Do It.
Moral of the story is take a hammer to your frame, and then you have to take it apart! A thermostat pic from that bike may have messed you up anyway... I have the housing mounted 180 degrees for the hose routing ;) |
Nice moral. unfortunatly I think riding weather is just around the corner, Im having enough trouble deciding if i REALLY want to send my forks and springs out to get re-valved. When It rains weeks on end its hard to not have the bike ready for a day with ONLY 40% chance of rain :mad:. I just need another bike to be my project.:)
| All times are GMT -7. The time now is 01:11 AM. |
