SuperHawk Forum
-   Knowledge Base (https://www.superhawkforum.com/forums/knowledge-base-40/)
-   -   Header pipe dent removal (https://www.superhawkforum.com/forums/knowledge-base-40/header-pipe-dent-removal-17672/)
Hawkrider Feb 24, 2009 03:08 PM
I thought I'd throw this out into the KB since I recently PM'd another member on this.
Re: Dent removal
Heres a little trick for that dent in the pipe. Fill that area with water. Wrap a towel around the dented area only and sit the whole thing outside in freezing weather, or in the freezer if you have one big enough. Ensure the dent is right in the middle of the water slug. In the morning the dent will be gone. I did this on a relatively thick steel Jardine header for my '79 Yamaha and it worked like a charm!
Thanks for the tip, but I don't fully understand the process you described. When water freezes it expands about 10%. Don't i need to seal the ends of the pipe? When the water freezes on the ends it will plug them enough to hold hundreds or even thousands of pounds of pressure. What does wrapping the towel do? The ends should freeze first but the towel is wrapped around the dented area first to insulate it and ensure that part freezes last. Once the ends freeze the water in the middle will be compressed and pressure will rise enough to push the dent out. If the dent is small enough it should push out all the way on the first try. How much water do I fill the pipes? You have to fill the pipe so there is enough water to build pressure - I'd say at least a foot on each side of the dent. Too much and you *could* possibly split the pipe, so don't go all out the first try. Guys do this on 2 stroke expansion chambers all the time.
HondaJim Feb 24, 2009 03:24 PM
I've seen this work on two stroke pipes, especially the expansion chambers, but thicker wall four stroke pipes seem to be a little tougher to do.
I had a set of pipes with a dent in one of the downtubes and I tried this method. Didn't work. What I ended up doing is putting rubber stoppers in the ends of the pipes with a bracket to retain them. 5 lbs. nitrogen pressure and then got the dent area cherry red with an oxy/act torch. Dent pushed right out. Try at your own risk. These were black pipes so I just repainted after the repair. It would probably leave a nasty looking burnt spot on unpainted pipes, although you might be able to sand/polish it out.
Hawkrider Feb 24, 2009 03:39 PM
FWIW, the Jardine pipes on my Yamaha are probably 1/16" thick carbon steel and are HEFTY! I couldn't believe it worked as well as it did. You have to use enough water and it's absolutely imperative that the dented area freeze last. I cannot stress this part enough.
The other thing is that almost everyone has access to water and a freezer. Not everyone has access to plugs, pressurized gas, and an oxyacetylene torch.
mboe794 Feb 24, 2009 03:43 PM
I've tried the freezing water trick more than once on 2 stroke pipes. Usually have pretty good luck. On large dents doing it twice or more produces good results.
Kendrick Feb 24, 2009 03:46 PM
I've heard about the same routine but with dry ice. That's how those paintless dent repair services do it from what I understand.
Byrdman Feb 24, 2009 04:04 PM
thats pretty smart.
gravelrash Sep 3, 2009 06:06 PM
header pipe dent fix by freezing of water
This worked brilliantly for me.
here is a link to a web album i shared with some of the boys i ride with. unfortunately in my haste to get it in the freezer, i forgot to take "before" photos.
note the freeezer temp is about -8 degrees Canadian, ie about 18 degrees F. not sure how that compares to your average modern home deep freeze. mine is about as old as I am ..and probably about as energy efficient...
http://picasaweb.google.ca/mbaxter99...at=directlink#
Dantheman Feb 15, 2016 04:59 PM
Now You See it Now You Don't
1 Attachment(s)
Attachment 19664This forum is one of the coolest thing to ever hit the world. Did the throw it in the freezer trick.
Dantheman Feb 15, 2016 05:10 PM
Dented header front cylinder
1 Attachment(s)
This is the before pic
Cadbury64 Feb 15, 2016 07:10 PM
Well I'll be darned! What a great idea. I've got a very similar dent to yours Dan. May be one day I'll give this a try.
finepooch Feb 15, 2016 07:25 PM
wow! when i started reading my skeptical mind immediately judged this as hocus pocus. then all the reports of successful repairs and i am transferring this file into the "strange but true" folder. nice tip.
smokinjoe73 Feb 15, 2016 10:00 PM
It is amazing, and to think water is also one of the only substances that is lighter as a solid than a liquid. God's own design.
finepooch Feb 16, 2016 04:41 AM
Originally Posted by smokinjoe73 (Post 393571)
God's own design.
LOL!:laughing2:
:bsflag:
Fastguy59 Feb 17, 2016 04:45 PM
I giving this a try tomorrow night when the overnight temps come back down into the freeze zone! Thnx for posting this!
Fastguy59 Mar 9, 2016 12:31 PM
I did give it a try but even with temps in the 18 degree range (digital thermometer measured) the water in the pipe would not completely freeze. I'm thinking the carbon coating inside the pipe may have some influence. I'm on the hunt for a friend with an empty chest freezer @ 0 degrees... More later..
E.Marquez Mar 9, 2016 05:24 PM
Chest deep freezer is what i have always used. I have three for beer making so just plan use in between fermentation periods:D
NZSpokes Mar 11, 2016 01:04 AM
Yerp done this on my 2 smoke pipe.
Make sure the wife is not home though.
waltr Mar 11, 2016 10:24 AM
Here in the pacific northwest we don't need to ferment in a freezer. There are only about 2 months that I even have to give any thought to temperature.
I do have 4 refrigerators though, and one of them actually has food in it!:p
E.Marquez Mar 11, 2016 11:22 AM
Ahh, the Oil thread of beer making... Fermentation process and Temps :p
I'll leave that for another forum and just say.. I control fermentation temps when i brew..and I think it matters ,,It made a difference in quality and consistency when I brewed in Corvallis Or, Fairbanks AK, South Carolina, California, and now Texas...but to each his own, do what makes beer for you.
CruxGNZ Mar 11, 2016 06:16 PM
Probably has nothing to do with our bikes, but interesting nonetheless.
Dented pipes can make power? What the...
NZSpokes Mar 11, 2016 11:23 PM
Dented pipes can make power? What the... Exhaust Header Bash! Testing Power Loss From Dents - Engine Masters Ep. 4 - YouTube
Thanks, that was a great watch.
Cadbury64 Mar 12, 2016 08:32 PM
After watching that, I feel a lot better about my dented header!
finepooch Mar 13, 2016 11:33 AM
all the sleep i lost because of the dented header on my aprilia mxv450 was for nothing. lol
NZSpokes Mar 17, 2016 11:50 AM
Does make on wonder if plugging it and heating water would work as well?
VTR1000F Mar 17, 2016 12:19 PM
I'm not really wondering, but I think you should video your attempt and have someone standing by (at a distance) to post the video here on the forum postmortem.
Cadbury64 Mar 17, 2016 01:14 PM
Well said! Look up "boiler explosions" on youtube to see the result.
Heating water to create pressure potentially results in catastrophic explosions, because if the pressure is released the water turns to steam and expands to many, many times its liquid volume.
It would be much safer to simply use hydraulic pressure with cold water, and a grease gun or similar to generate the pressure.
The nice thing about the ice method is that the ice forms the necessary perfect seal either side of the dent, before the liquid by the dent freezes and expands.
Funnily enough Spokes, I was also bidding on the pipe that you bought, with the intention of using the headers to replace my dented system. You got it for a good price while my back was turned...
NZSpokes Mar 17, 2016 04:33 PM
You just know that makes me want to try it more......:D
VTR1000F Mar 17, 2016 05:10 PM
My work here is done.
Don't forget the video.
NZSpokes Mar 17, 2016 05:17 PM
So it was you that knocked it up so high!:D
Cadbury64 Mar 17, 2016 07:12 PM
Sorry about that, mate. Not sure I'd consider $25 high though.
