Front wheel spacers. Which one where?
Old Oct 21, 2013 | 11:49 AM
jdobeckj's Avatar
jdobeckj is on a distinguished road
Yesterday I brought my wheels in to have new tires put on. I made the critical mistake of NOT identifying how the front axle bushing were to be re installed.. Can someone please take a look and advise, I dont want to screw this up.
Thanks Josh
Old Oct 21, 2013 | 11:53 AM
sailorjerry's Avatar
Thanks Josh
If you're talking about the spacers, they can only go on one way, if you try to put them on backwards the left rotor will hit the fork.
Old Oct 21, 2013 | 11:54 AM
JamieDaugherty's Avatar
The spacer? It goes on the right side as you are sitting on the bike. Is that what you mean?
Old Oct 21, 2013 | 11:58 AM
jdobeckj's Avatar
Yeah, Spacer (bushing) there are two one slightly longer than the other one. I tried to reference bikebandit and their diagram says some thing different.. Im confused
2000 Honda Parts, 2000 Honda OEM Parts - BikeBandit.com
Old Oct 21, 2013 | 12:04 PM
Unfortunately I'm not running a stock front setup or I would check. Probably best to use Jerry's advice. The rotors will be evenly spaced between the forks if it is correct.
Good luck!
Old Oct 21, 2013 | 12:18 PM
saige's Avatar
the boss
when you go to put the wheel on,as you are sitting in front of it,the small spacer is on the right (clutch lever side) the big spacer on the left side (front brake lever side.
Old Oct 21, 2013 | 12:26 PM
jdobeckj's Avatar
Sweet.......... I tried a both ways ( they both fit) but when the larger spacer is on the clutch side the brakes drag slightly... but damn, I wont be making this mistake again.. Thank you all..
thedeatons
Nov 27, 2013 11:30 PM
erno
Jun 18, 2012 07:52 PM
jeephawk
Apr 10, 2012 08:42 AM
Duckhawk
May 26, 2010 03:13 PM
ZZRGuy
Jun 16, 2007 05:10 PM
