Don't need Spool
Old Aug 19, 2006 | 05:54 PM
calitoz's Avatar
Escape Reality
Don't need Spool
Since I already have a stand that required spools and not wanting to buy another for my hawks, I've been trying to figure out how to make it work. I don't want to weld a thread-mounts on since I have never welded aluminum before and I don't want to tap the swingarm. So today while I was working on it, I realized that there is no need add spools to make it compatible for my stand.
If you look at the rear cush drive..I think that's what they are called, you will notice that it is hollow. So I just went and bought a rod and stick it through..Voila spools.
Mind you I had to drill one side to make it bigger since the inner opening of the sprocket side is a tad smaller than the whole opening of the drive and you cannot change tire with this setup.
just an idea you might want to try...now for those who has a stand that don't require spools...ignore me.
Old Aug 19, 2006 | 09:31 PM
marmaladedad's Avatar
Hmm?
I'm bad at reading. I'm a visual learner. Peekchurrs?
Old Aug 20, 2006 | 04:51 AM
Mind you I had to drill one side to make it bigger since the inner opening of the sprocket side is a tad smaller than the whole opening of the drive.
I am going to fabricate a removable one with welded spacers tommorrow which will allow me to pulled it out when not in use. Now if you want to have it permanently mounted, you can always use threaded rod and nuts.
Very nice.This is how I lift my SH as long as I do not need to remove the rear wheel.
Another variation of what you did is to use a piece of all thread that fits the larger diameter of the hollow axle.. turn down the left side so it fits through the smaller diameter, thread it and add some spools to the threaded rod. You could thread the "spools" with the right one lock in place (thread lock or a jam nut) and use the right one as a lock nut to hold the rod in place.
Personally I bought a spare swing arm, and will have some spool mounts TIG welded in place, then swap swing arms. Spend some time polishing up the old one, then sell it.
Old Aug 21, 2006 | 07:27 AM
altosuperhawk's Avatar
I've done the same thing with my '98 Superhawk. Took a piece of steel rod that fit snugly through the right side and turned down the final two inches that pass throught the left end of the axle. Drilled out a spool, press fit, tapped and screwed a bolt to secure it to the right end of the rod. Slip fit a spool on the smaller diameter left end and drilled a small hole for a hitch pin to keep the removable spool from sliding off. Now my Pit-Bull holds the bike securely with no more slip-sliding forward with the previous under swingarm method. Much safer for those frequent 350 mile chain cleaning and lubing drills.
Old Sep 18, 2006 | 05:16 PM
calitoz's Avatar
Escape Reality
added picture for those without imagination :-d
Old Sep 18, 2006 | 05:39 PM
superhawk22's Avatar
For those that are lazy, I've been using my pad stand right behind the weld on the swing arm without any sliding at all. Just FYI, good idea though calitoz!
chiknhauk
May 1, 2012 04:03 PM
finepooch
Oct 29, 2010 01:01 PM
pigwings
Nov 27, 2009 10:37 AM
j shizzy wizzy
Jun 21, 2009 05:38 PM
newb007
Sep 14, 2008 06:33 PM
