cross referencing
Old Sep 26, 2008 | 09:45 PM
MisfitToy's Avatar
Shredding Asphalt
cross referencing
So lets make a list off all items that can be transfered from bike to bike. Or even Car to bike.
Any and all information is use with own risk. Its your responsibility to double check the information.
You can use the valve cover bolts off of a CBR600 on a superhawk also a wix 51356 filter can be used on a hawk with some minor clearance of the little bellypan
if anyone knows what sprockets can be swapped.. ie RC51??
Old Sep 26, 2008 | 10:04 PM
MisfitToy's Avatar
Shredding Asphalt
Sprockets according to JT and a product number search
JTF 333.16
Available teeth numbers in: 15, 16
Please select a model: :
Type
Remark
Country
Year
16 teeth
Honda
VF750 F
96
VFR750 FV,FW
RC36
97-98
VFR750 FL,FM,FN,FP,FR,FS,FT
RC36
90-96
VFR750 FJ,FK
RC24
88-89
VFR750 FG,FH,FJ,FK
RC24
86-89
VF750 CD/2 Magna Deluxe
95-04
VF750 C Magna
99-04
VF750 C Magna
RC43
94-98
VFR750 F Interceptor
90-97
CBR900 RR
93-95
919 (CB900 F)
07
919 (CB900 F)
02-06
CBR900 RR Y,1,2,3 Fire Blade
00-03
CBR900 RR N,P,R,S Fire Blade
SC28
92-95
CB900 F Hornet
02-06
CBR929 RR
00-01
CBR954 RR
02-03
CBR1000 RR
04-05
CBR1000 RR
06
CBR1000 RR
07
RC51 (RVT1000 R)
00-06
VTR1000 SP-2
02-06
VTR1000 SP-1
00-01
VTR1000 F-4,5 Fire Storm
04-05
CB1000 R-8
08
CB1000 RA-8 (ABS)
08
CBF1000 F
06-07
CBF1000 F
08
CBF1000 F (ABS)
06-07
CBF1000 F (ABS)
08
CBR1000 RR-4,5 Fireblade
04-05
CBR1000 RR-6,7 Fireblade
06-07
CBR1000 RR-8 Fireblade
08
VTR1000 F-V,W,X,Y,1,2,3 Fire Storm
97-03
VTR1000 F Superhawk
98-05
Old Sep 26, 2008 | 10:06 PM
MisfitToy's Avatar
Shredding Asphalt
for a 43 tooth rear
JTR 302.43
Available teeth numbers in: 39, 41, 42, 43, 44, 45
This sprocket is also available in alloy:
JTA 302: 43, 44, 45
Type
Remark
Country
Year
43 teeth
Honda
CBR600 FM,FN,FP,FR,FS,FT
PC25
91-96
CBR600 SJR
96
CBR600 F 2/ F 3
91-96
919 (CB900 F)
07
919 (CB900 F)
02-06
CBR900 RR
93-95
CB900 F Hornet
02-06
CBF1000 F (ABS)
08
CBF1000 F (ABS)
06-07
CBF1000 F
08
CBF1000 F
06-07
CB1100 SF X-11
SC42
00-03
Bike Alert Plc, London, UK
Old Sep 26, 2008 | 10:08 PM
MisfitToy's Avatar
Shredding Asphalt
for the 15 front
JTF 333.15
Type
Remark
Country
Year
15 teeth
Honda
VF750 C V45 Magna
94-03
VF750 CD/CD2 V45 Magna Deluxe
95-03
Old Sep 26, 2008 | 10:12 PM
MisfitToy's Avatar
Shredding Asphalt
More infor on the wix filter. Wix makes napa gold not napa select only The gold series. so you can go to wix and type in this code and it will bring up other filters that match
Part Number:51356UPC Number:765809513563Principal Application:Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-08), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip.</B>All ApplicationsStyle:Spin-On Lube FilterService:LubeType:Full FlowMedia:PaperHeight:3.402Outer Diameter Top:2.685 Outer Diameter Bottom:Closed Thread Size:20X1.5 MMBy-Pass Valve Setting-PSI:8-11Anti-Drain Back Valve:YesBeta Ratio:2/20=6/19Burst Pressure-PSI:363Max Flow Rate:9-11 GPMNominal Micron Rating:19
Gasket DiametersNumberO.D.I.D.Thk.Attached 2.475 2.173 0.233
Close Window
Old Sep 28, 2008 | 06:57 PM
MisfitToy's Avatar
Shredding Asphalt
Just ordered a sprocket chain combo for a 93-95 cbr900 its a 530-108 link so I have to bust some chain. Ill report how it fits.
oicdn
Jul 30, 2015 07:09 PM
mikstr
Dec 14, 2009 06:04 PM
A Team
Jul 16, 2007 07:05 AM
Chitownson
May 28, 2007 11:08 AM
spEEdfrEEk
Jul 2, 2004 10:17 AM
