cross referencing
So lets make a list off all items that can be transfered from bike to bike. Or even Car to bike.
Any and all information is use with own risk. Its your responsibility to double check the information. You can use the valve cover bolts off of a CBR600 on a superhawk also a wix 51356 filter can be used on a hawk with some minor clearance of the little bellypan if anyone knows what sprockets can be swapped.. ie RC51?? |
for a 43 tooth rear
JTR 302.43 http://www.jtsprockets.com/fileadmin...all/jtr302.jpgAvailable teeth numbers in: 39, 41, 42, 43, 44, 45 This sprocket is also available in alloy: JTA 302: 43, 44, 45 Please select a model: : Type Remark Country Year 43 teeth Honda CBR600 FM,FN,FP,FR,FS,FT PC25 91-96 CBR600 SJR http://www.jtsprockets.com/fileadmin...ountry/usa.gif 96 CBR600 F 2/ F 3 http://www.jtsprockets.com/fileadmin...ountry/usa.gif 91-96 919 (CB900 F) http://www.jtsprockets.com/fileadmin...ountry/usa.gif 07 919 (CB900 F) http://www.jtsprockets.com/fileadmin...ountry/usa.gif 02-06 CBR900 RR http://www.jtsprockets.com/fileadmin...ountry/usa.gif 93-95 CB900 F Hornet 02-06 CBF1000 F (ABS) 08 CBF1000 F (ABS) 06-07 CBF1000 F 08 CBF1000 F 06-07 CB1100 SF X-11 SC42 00-03 Bike Alert Plc, London, UK |
for the 15 front
JTF 333.15 http://www.jtsprockets.com/fileadmin...all/jtf333.jpgAvailable teeth numbers in: 15, 16 Please select a model: : Type Remark Country Year 15 teeth Honda VF750 C V45 Magna http://www.jtsprockets.com/fileadmin...ountry/usa.gif 94-03 VF750 CD/CD2 V45 Magna Deluxe http://www.jtsprockets.com/fileadmin...ountry/usa.gif 95-03 Bike Alert Plc, London, UK |
More infor on the wix filter. Wix makes napa gold not napa select only The gold series. so you can go to wix and type in this code and it will bring up other filters that match
Part Number:51356UPC Number:765809513563Principal Application:Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-08), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip.</B>All ApplicationsStyle:Spin-On Lube FilterService:LubeType:Full FlowMedia:PaperHeight:3.402Outer Diameter Top:2.685 Outer Diameter Bottom:Closed Thread Size:20X1.5 MMBy-Pass Valve Setting-PSI:8-11Anti-Drain Back Valve:YesBeta Ratio:2/20=6/19Burst Pressure-PSI:363Max Flow Rate:9-11 GPMNominal Micron Rating:19 Gasket DiametersNumberO.D.I.D.Thk.Attached 2.475 2.173 0.233 Close Window |
Just ordered a sprocket chain combo for a 93-95 cbr900 its a 530-108 link so I have to bust some chain. Ill report how it fits.
