1995 VFR CLIP ON INSTALL
Just installed the 95 clip ons. Works wonders and feel great. Adjusted so misses everything by 1/8 inch.
I unbolted the brake cable block down on forks. 10 mm
I put the throttle cable back thru the forks and adjusted the cables accordingly.
I ground down the nib on the starter switch and wrapped the bar with electrical tape (6-8 wraps) the switch just compresses down tight. Nib was on the bottom and did not want to mess with it. No pressure on it.
The throttle cable had a top cover nib so I drilled the hole and installed the throttle.
Left side needed nothing but installing the parts back on
Easy to do and worthy of an hour or two anytime.
Thanks again for everyone who has added info to the sight
